Old 06-02-2009, 03:52 PM
TheAverageJoe's Avatar
TheAverageJoe TheAverageJoe is offline
Vehicle: 2006 Dodge Ram SLT
Trim Level: SLT Quad Cab
Color: Atlantic Blue
Rep:21
TheAverageJoe is on a distinguished road
Send a message via AIM to TheAverageJoe Send a message via Yahoo to TheAverageJoe Send a message via Skype™ to TheAverageJoe
Default Driver's side seat foam problems? I have the cure!
For any of you driving a 2003, 2004, 2005, 2006, 2007, or 2008 Dodge Ram 1500, 2500, or 3500 and have had your driver's side seat foam fail you. I have the cure. If you have a Lowe's and a Hobby Lobby near you, it'll only cost you around $13.00 and a little skill rather than $152.00 for new foam from the dealer. Not to mention, that new foam is going to fail you just like the old one.
Here's what you'll find when you peal back the upholstery.
While searching the web for an after market part or easy inexpensive fix, I came across this link in a Dodge Cummins Diesel forum.
http://www.*****************/forum/6-...98-seat-2.html
The frames of theses seats have a boxed frame that joins on the top of the frame and leaves an exposed sheet metal edge. This edge in addition to the sliding motion getting in and out of the trucks is tearing our foam.
Seat frame; notice the metal edge, but also notice the wires held by springs, more of that later.
The weld at the very back had some burrs, they may have started the tearing of the foam. I took a ball peen hammer, rolled the edge of the metal down, and then filed the burrs and any protrusion I thought might tear the foam.
Before reinstalling the foam, I glued some burlap over the frame. (Sorry no pic of that.)
(Burlap is approx. $2.99 a yard at Hobby Lobby. 1 yd will do 2 seats.)
For the wires with the springs, this is where the pad needs to go, directly on these springs. The springs are what provide the cushion when hitting bumps and stuff. The foam design intends to distribute the weight with out fatiguing your butt. (I don’t think they quite got that part down yet.)
I used 2 inches of foam, 1 inch of 20 lb & 1 inch of 40 lb. I also place a piece of vinyl between the foam and the springs to prevent the springs / wire from tearing the foam. 20lb goes on top, it's softer.
(Hobby Lobby carries a 14"x14"x2" piece of foam that works perfectly. No cutting necessary.)
(Also, be sure to glue a piece of burlap to the bottom of the 2" foam. If you don't it'll start snowing under your seat from deterioration. The burlap strengthens it too.)
Pic just shows where it goes, doesn’t include all the layers. I’d get busy and forget to take pics.
All the tears I’ve seen, start along the bottom or the back corner, just like mine. I also noticed mine had a big air pocket where the mold wasn’t filled correctly. That’s exactly where the tear started.
I filled all the torn gaps with glue, (Weldwood landau top adhesive.) and pressed it back together. Then I glued several layers of thin burlap to the foam.
(Lowe's carries a spray on 3M water based adhesive...works great.)
http://www.shop3m.com/62497749309.html
The center of the seat will rise with the pad added between the frame and factory foam, while the sides stay the same height, this takes the pressure off the hips & or butt.
The edges at the frame are fairly thin because the factory cushion is molded to fit around the frame. To help offset these deficiencies, I added a inch of foam to the outer and back panels.
(The 1" green foam at Hobby Lobby works just fine. You sit a little higher than you used to, but it'll settle in time.)
Pulled all back together, the seat has a slight “poofy” look, but it’s a heck of a lot more comfortable, and should last much longer too.
(Mine looks like a pillow top mattress...and I love it.)
I give all the credit to "cntryby" of the Dodge Diesel Cummins Forum.
"Break Time's over, Back on your heads."
Old 06-02-2009, 04:29 PM
300 Addict's Avatar
300 Addict 300 Addict is offline
Vehicle: Chrysler 300
Trim Level: Touring
Color: Satin Jade Metallic
Rep:317
300 Addict is a jewel in the rough300 Addict is a jewel in the rough300 Addict is a jewel in the rough300 Addict is a jewel in the rough
Wow man! That is an excellent writeup with great tips! Thanks for sharing it here with us!
Old 06-02-2009, 05:43 PM
kineticenrage kineticenrage is offline
Vehicle: 2005 Ram
Rep:17
kineticenrage is on a distinguished road
very nice write up.
Old 06-02-2009, 10:55 PM
Sparky's Avatar
Sparky Sparky is offline
Vehicle: '06 Ram Quad Cab HEMI
Color: FLAME RED
Rep:23
Sparky is on a distinguished road
I noticed that my seat is starting to take some abuse, thanks for the info I'm sure I'll use it.
Old 06-02-2009, 11:02 PM
08quadram's Avatar
08quadram 08quadram is offline
Vehicle: 08 Ram Quad 1500
Color: silver
Rep:22
08quadram is on a distinguished road
Very nice. I was just thinking the other day when i got out, that the edge of the seats were probably not going to last long. They take a lot of abuse it would seem.
Mike
'08 1500 Ram, Quad 4x4 Bighorn, Silver, 20" wheels, 5.7 Hemi/MDS, 3.92 axles
"Meddle not in the affairs of dragons, for thou art crunchy and good with catsup" -Doc, IFSJA
Old 06-03-2009, 09:07 AM
Rep:21
It's an engineering flaw.
The 2009 models have been corrected of it, or so I'm told.
It's also rumored that the foam cushion supplier provided a faulty/substandard product.
I know mine was formed incorrectly.
I didn't buy my RAM new, but those who have, and caught it in time, said theirs was replaced under warranty by the dealership...sometimes under protest.
So if you have this problem within your warranty time/mileage, you may have to lobby with the service/parts manager(s).
As far as I can tell this is a cheap/easy/quick fix that will last the duration of the truck. Of course, in anyone else's situation, it may depend on the use/abuse you give your truck and the skill level in which you have applied said fix.
Good luck to everyone who had to follow this thread to fix where Dodge fell short.
Old 06-03-2009, 11:07 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Dang, that's an awesome write-up! Definitely don't want that chewed up driver's side seat like you always see with some of the older trucks. I will have to keep an eye on mine and see if made any changes on the 08 models.
Old 06-03-2009, 12:14 PM
Rep:4072
Funny you should write that, because I am noticing where mine is starting to show signs of "weakness" also, so I will definitely have to remember this, thank you for sharing. Very helpful. I just try not to slide out of the seat and actually climb out, make it last as long as possible.
Old 06-03-2009, 12:59 PM
Rep:21
Yeah, I can only figure that the previous owner of my truck was a short fat guy (not that there's anything wrong with that). It looks as if he just swiveled around in the seat and slid out.
Right after buying my Ram back in September, I put nerf bars on it just for that purpose. Not to mention the kids couldn't get in and out. I now, make a conscience effort not to slide or scoot in or out of my seat.
Old 06-03-2009, 08:22 PM
jamesb0 jamesb0 is offline
Vehicle: 2006 Ram 2500 Quad/ SB / 4x4
Color: Flame red
Rep:57
jamesb0 will become famous soon enough
Thanks I was just thinking about that the other day when climbing in
