Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 06-04-2009, 04:20 AM
bwoodredkneck's Avatar
bwoodredkneck bwoodredkneck is offline
Vehicle: 2001 dodge ram 1500 4X4
Rep:24
bwoodredkneck is on a distinguished road
Send a message via MSN to bwoodredkneck
Default baja lights?
alright so i baught some baja lights from auto zone and i places em on my bumper and every thing is all hooked up rite. But for some reson i keep blowin fuses like crazy and ive had to buy 2 new fuse holders and when i try to by pass the fuse one of the wires starts to melt. and every thing is hooked up rite. there grounded to my bumper i have the power comin straight off the battery i have the switch in the truck all right. any suggestions?
Old 06-04-2009, 05:40 AM
Rep:24
nvm i got it i had to run a seprate wire off of each lite to the switch
Old 06-04-2009, 08:22 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Ahhh... so they were trying to make it tricky. Got any pics of the lights?
Old 06-04-2009, 06:29 PM
Rep:24
na but i can get some
ill have em up in like 45 mins
Old 06-04-2009, 06:39 PM
Rep:24
Baja lights
Old 06-04-2009, 06:48 PM
Sparky's Avatar
Sparky Sparky is offline
Vehicle: '06 Ram Quad Cab HEMI
Color: FLAME RED
Rep:23
Sparky is on a distinguished road
What size wire did you use to go to the lights? You should not have to run separate wires unless you are using to small of a gauge wire and that would cause heat in the wire. Then you have to check if the wire going to the switch from the battery is right. Other wise I would have guessed a pinched wire, or shorted someplace.
Old 06-04-2009, 06:58 PM
Rep:24
they were pretty small wires i ended up usin a thicker wire for the power but the deal was that both the lights ran into one wire and it was e size of speaker wire so i went back and used seprate wires and ran both to one switch along with the power now they both work fine
Old 06-04-2009, 07:08 PM
chithead's Avatar
Rep:2078
Those look pretty good on there actually. Good job
Old 06-04-2009, 07:37 PM
Rep:24
those are the ones i use to have runin on top till my crazy x knocked em off with a bat. i had them wired up to my amp and the switches were mounted on the side of my center console
Old 06-04-2009, 10:23 PM
Sparky's Avatar
Color: FLAME RED
Rep:23
Always use wire rated for the job. Lights in trucks run on 12vdc and pull more amps than in your house because of the lover voltage. two lights @ 55 watts is a little over 9 amps. That would be a minimum of 16gauge wire. I had a buddy start his truck on fire because he used the wrong wire ( plus he was a dumb a$$). Always use a fuse, and if it blows there is a reason why and fix it.
Sorry for rambling, don't wont to see people get hurt. I am an electrician and I have seen some big mistakes that have cost people big $$$$$$$ and do not want that to happen to anyone here.
