Low Pressure sensors - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-06-2009, 02:27 PM
jimf5 jimf5 is offline
Vehicle: 2009 Ram 1500 Crew Cab
Color: Detonator Yellow
jimf5 is on a distinguished road
Default Low Pressure sensors
Hi All:
All 09's are supposed to have a low tire pressure monitor with the sensors "attached" to the rims. Has enyone changed to "custom " rims and if so how did the installar handle the sensor transfer? Did they use new sensors or transfer the old ones to the new rims? Any info would be a real help when I go to purchase new rims.
Thanks
jimf5
Old 06-06-2009, 02:56 PM
You can transfer your existing sensors to the new wheels. Some wheels come with pre-drilled holes but if you select a set without the holes, the wheel shop can help you. Also, talk to the wheel mfgr before you buy as they can drill them for you too.
Old 06-07-2009, 03:43 PM
Maddog:
Thanks for the reply. I started looking and pricing wheels this morning and found out the sensors are in the valve stem. It lists a rebuild kit for the "tire pressure monitor sensor" and the picture shows the parts go in the stem. I was thinking it was something else, like a sensor glued to the rim. It was only $2.00 per wheel.
Jimf5
Old 06-07-2009, 03:56 PM
HEMILANCER's Avatar
Vehicle: 09 Dodge Ram
Color: deep water blue
Rep:85
i think u have to have rims with special valve stem holes to mount the sensors b/c they are held on by the valve stem. another option is to see if dodge can diable the tire monitor system to keep the light out that way u dont have to worry about sensors at all.
Too many mods to fit here!
Old 06-07-2009, 06:07 PM
Good point...you'll need a set of rims that the pressure sensor/valve stem assy will fit! I was thinking of some of the aftermarket systems that you had to have a second set of holes to use them.
And the stock ones can be reused. They only take a few revolutions to recalibrate to the computer once they've been removed.
When I re-did the wheels on my Chrysler 300 SRT8 I had moved all of 20 feet and they were all back on!
