Old 06-08-2009, 09:55 PM
jj141979 jj141979 is offline
jj141979 is on a distinguished road
Default leveling front end with torsion bars alone???
Hi Guys new to the sight! I have been surfing for awhile though. I have an 03 Ram and want to upgrade the tires from 265/70-17 to 285/70-17, i also want to level the front end. Can I raise the front end up 2in or so with the torsion bars alone, I will be getting an alignment also. Also will there be any clearence issues if I dont get the front leveled?? THANKS GUYS GREAT SIGHT!!
Old 06-09-2009, 01:53 AM
2 inches is a lot to raise just using the torsion bars but I've seen folks raise them more with just the bars.
I haven't tried this particular size tire on your model Ram so I'm not sure if you will have rubbing issues but I suspect you won't except maybe at full steering lock. You are only up a +1 on the size.
Old 06-10-2009, 01:37 AM
Thanks Maddog! I think (HOPE) i will be alright. anybody else try this?? THANKS!
Old 06-10-2009, 09:50 AM
57Hemi08's Avatar
57Hemi08 57Hemi08 is offline
Vehicle: 2008 Dodge Ram
Trim Level: SLT Big Horn
Rep:42
57Hemi08 is on a distinguished road
I use to raise the torsion bars on Ford Rangers all the time. Never had a problem. Just don't screw the adjuster bolt all the way in, leave a little room for some flex in the suspension. Make sure you turn the adjuster bolts on both sides the same amount ie. 3 and 1/4 turns on drivers side then turn the passenger side 3 and 1/4 turns.
