Old 06-08-2009, 09:53 PM
dkersey dkersey is offline
dkersey is on a distinguished road
Unhappy Totally Confused
Well I hope that some one here can help me out. I will try to be brief. 1997 Ram Magnum 5.2L. Here is what is happening to me. A few weeks ago the computer set a P0207 code. Ok. Injector #7 Ckt. Checked wiring and it was ok. Put in new(rebuilt)injectors. Cleaned throttle body and all ports including MAP and IAC. IAC is functioning properly. Same thing. If I unpleg any other injector it sets a code for that one(injector #1 P0201 etc.)I replaced the TPS Sensor. Someone on a forum said that it may be the cause. Still getting P0207. Replaced PCM with rebuilt. Ran great for about 6 blocks and set P0207. Now I am not the smartest person in the world but I am having a real hard time beliving that the code has anything to do with the #7 injector. Moved #7 to #1. Still get P0207. Checked the wiring again. Used a DVM Meter and ohmed out the wires(power disconnected of course). Wiring is good. I am now at a loss as to where to turn. I REALLY like the truck and it has been steady eddie with no problems. Is there anything or anywhere else that I should be looking. I guess the only thing that I have not replaced is the MAP sensor. I could use some help here. I don't know where else to turn. Starting to get expensive.
Old 06-08-2009, 10:32 PM
boostjunkie1's Avatar
boostjunkie1 boostjunkie1 is offline
Vehicle: 2008 Hemi Ram
Rep:62
boostjunkie1 will become famous soon enough
- - - Wow.... Only thing I would say is to replace the wiring because you have changed everything else...... Make sure that the wire does not have a small crack in it allowing it to vibrate against the block causing a short. The small cracks can get you and you will never see them unless you have a megger and wiggle the wires just like they are vibrating when the truck is going down the road... Good Luck!
Old 06-09-2009, 12:12 AM
Default THANK YOU boostjunkie1
I have got to say a big thank you to boostjunkie1. I posted the problem and you replied pretty quick. I found the problemwith your help. I have been doing electronics and electrical for thirty years and it still never ceases to amaze me how often I tend to over complicate things. The problem turned out to be in the wiring even tough it read good with a meter. When I changed out the old cold air intake for a new one I nicked the #7 injector wire. Not enough to cut it all the way through but enough to allow a single strand of wire to dangle down and touch the new nut for the cold air intake. This all made sense after I took a break and read your post. Sometimes it just takes another set of eyes to see through to the problem. Truck is running a good as it always has and I am a happy camper. THANKS AGAIN!!!!!!!!!
Old 06-09-2009, 12:45 AM
Way to go, boostjunkie1! Beans to ya!!!
Old 06-09-2009, 01:12 AM
Rep:62
........OH YEEEEEEEEEEEAAAAAAAAAAAAaaaaaaaaaaaaaaaaa...... That is what I am here for .........Glad to see you got her fixed
Old 06-09-2009, 02:09 AM
Yep. Got her done. Just had to have boostjunkie1 take me back to the first principle of troubleshooting. Keep It Simple Stupid. Thanks again!!
Old 06-09-2009, 12:29 PM
Rep:62
.....Not laughing at you....laughing with you ......I have done this so many times with Cars and Boats that as soon as I read the first post that is all I could think of............KISS
