2005 Ram Wheels On A 2005 Dakota - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-13-2009, 10:15 AM
johnydodge
Default 2005 Ram Wheels On A 2005 Dakota
Does anyone know if wheels from a 2005 Ram 1500 will fit a 2005 Dakota? Both have 5 lug nuts.......not sure of pattern.
Old 06-13-2009, 11:19 PM
nim81's Avatar
nim81 nim81 is offline
Vehicle: 2006 TRX4 SLT Ram 1500
Trim Level: TRX4
Rep:19
nim81 is on a distinguished road
they are both 5x5.5 or 5x139.7mm
Shhh! Chocolate. Once them deers smell that birthday cake them sumbitches will come a running.
Old 06-14-2009, 12:40 AM
Welcome to the forum. Here's some wheel specs for ya on the Ram wheels that might be of some help.
Wheel Specifications:
1994-1999 1500 2WD/4WD Aluminum Wheels
• Lug Pattern - 5 on 5.5", 1/2" bolt
• Rim Size - 16x7.0"
• Offset - +13.97mm
• Backspace - 5"
• Max Tire Size -
• 15x8.0 rims with 3.5" backspace will fit, but they stick out of the wheel wells.
Torque Spec
• 80-110 ft lbs (108-150 Nm) on 5 stud wheels
2000-2003 1500 2WD/4WD 17" Steel Wheels (Chrome or painted)
• Lug Pattern: 5 on 5 1/2
• Rim Size: 17x7"
• Fits 94 and up 1500 trucks
2000-2003 1500 2WD/4WD 17" Aluminum Wheels:
• Weight: 23.5 pounds
• Rim Size: 17x8"
• Actual width edge to edge: 9 1/16"
• Backspacing: 5 9/16".
• The space from the outside edge to the mounting surface (against the rotor) is 3 1/2".
• offset calculate: 1 1/32"
When you get the chance, go to the Newbie Section and tell us a bit about you and your truck!
Old 06-15-2009, 01:24 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
There is a 2005 Durango sporting the 20" rims and tires from a Ram around town here.
