Old 06-13-2009, 10:50 PM
pauly75 pauly75 is offline
Vehicle: 1998 Ram 1500
Trim Level: Laramie SLT
Color: Maroon
Rep:14
pauly75 is on a distinguished road
Default Tire question
I've tried searching on here, and Googling this.
I need tires and have been looking around. I've found these,
LT305/70-16 Do you think these will fit my stock 98 Ram 1500? Right now it has 265/75-16's on there.
Or I found a set of rims/tires off an 06 Ram 1500. Those should be a direct swap, correct?
Thanks for any help.
Old 06-13-2009, 10:55 PM
Here's some specs on what fits your Dodge. All you have to do is make sure on the spec on the replacement wheels:
1994-1999 1500 2WD/4WD Aluminum Wheels
• Lug Pattern - 5 on 5.5", 1/2" bolt
• Rim Size - 16x7.0"
• Offset - +13.97mm
• Backspace - 5"
• Max Tire Size - 305
• 15x8.0 rims with 3.5" backspace will fit, but they stick out of the wheel wells.
Old 06-14-2009, 03:49 AM
ph3nom3non03's Avatar
ph3nom3non03 ph3nom3non03 is offline
Vehicle: 2000 Dodge Ram 1500 4x4
Trim Level: SLT LARAMIE
Color: Intense Blue Pearl
ph3nom3non03 is on a distinguished road
i have 315/70r16 on my dodge with no lift and 4 wheel drive and only rub on the inner plastic liner when turning sharp so i would say you shouldnt have any problems oh and my truck is a 2000 same body style... but good luck
Old 06-16-2009, 02:17 PM
Color: Maroon
Rep:14
The MT's fell through. Ended up finding these on Craigslist.
Old 06-16-2009, 03:30 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Hey those aren't bad. I like them Mickey T Baja Crawlers, but the price has stopped me everytime from getting them. That's cool that your Dodge center cap fit on those wheels!
Old 06-17-2009, 12:37 AM
Color: Maroon
Rep:14
Yeah, those Mickey's were nice, and the guy was only asking $400, with the rims. I called a day late.
Old 06-17-2009, 10:22 AM
chithead's Avatar
Rep:2078
Dang, that's the way it always goes too.
