Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V6 Specific Topics
Old 06-17-2009, 12:12 PM
RSLBOWHUNTER RSLBOWHUNTER is offline
RSLBOWHUNTER is on a distinguished road
Question Over drive problem
I have a 1996 dodge ram 1500 4x4 with a 01 motor and auto tranny.
When i first drive it the overdrive button light is on for about
5 miles, then it will cut off and shift into od.
What would cause this?
It is very consistant on kickin into od at that point.
After it kicks in i can cut it on & off.
Didn't know if it a mileage thing or a temp. Thing.
Old 06-17-2009, 12:29 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
Hello and welcome!
I am sorry I don't have an answer to your problem but there are plenty here who will be able to help you! Just give them a little time to see the post, I just didn't want you to feel ignored!
Why don't you head over here while you are waiting and introduce yourself so we can welcome you here proper like? Tell us more about your truck and such!
Old 06-17-2009, 02:43 PM
sarge's Avatar
sarge sarge is offline
Vehicle: 2008 ram quad cab
Color: sunburst orange
Rep:16
sarge is on a distinguished road
my best suggestion would be to take it to an autozone or somewhere that would check the diagnostic code for free (at least they will here in laurel, ms). get the code and then you can post it on here or look it up for yourself. that'll help narrow it down a lot. i'm gonna guess it's slippage (especially if you've hauled stuff that would have heated it up pretty good). what could be happening is that the computer reads the slippage until the tranny gets heated up (which causes the clutches to actually expand and engage better). then it corrects the fail-safe and allows tranny to go into OD. since you probably drive the same routes each day, it usually takes it about the same amount of mileage/time to reach that temp. bottom line is it could be different problems causing it and the best way to make a good guess is to scan it and see what the diagnostic code(s) are (the one making your OD light come on when you first crank it). hope this helps.
My name is Aaron and I hate stupid people.
Old 05-06-2012, 05:35 PM
rebel5422's Avatar
rebel5422 rebel5422 is offline
Vehicle: 98 ram 1500, 96 ram 3500
Color: 98 met red, 96 Black
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
rebel5422 is on a distinguished road
did u ever figure out the problem? i know this is about a 3yr old thread but im having a very simular problem... my mom totaled her 01 with a v6 and auto we bout a 98 with a v6 and auto but the motor was blown.. o1 engine and trans went into the 98 tried running the 01 ecm but the times it would fire up it would run poorly but trans would run shift correctly put the 98 ecm in the engine runs great but the trans wont shift to overdrive, the od off light comes on and the trans temp light follows shortly after... there are no engine codes either? some one said to swap the 01 govener pressure selonoids and internal wiring and other sensors to the 98 ones and this would fix due to the difference in year models they are wired differently? is this correct? all connections on the 98 harness fit the 01 trans? im kinda lost and have searched for an answer everywhere... thanks for any help
