tonneaucovered.com
Old 06-19-2009, 07:49 AM
coastie_30 coastie_30 is offline
coastie_30 is on a distinguished road
Default leveling kit question
just had my local shop put in a pro comp leveling kit, the torsion key kind, on my 2005 dodge ram. after i drove out of there i noticed that it was really bouncy. its also kinda sketchy on speed bumps. my question is ....is the bounce because my oem shocks are now extended too far with the new ride height? and if so would a taller shock alleviate the problem? i already ordered taller shocks but i want to know for sure that this would solve the issue.
Old 06-19-2009, 05:21 PM
boostjunkie1's Avatar
boostjunkie1 boostjunkie1 is offline
Vehicle: 2008 Hemi Ram
Rep:62
boostjunkie1 will become famous soon enough
YEP.............The best way to level the front is a new set of Coil-Over Shocks with Springs that are designed to level the front end out with new shocks!!!!
Old 06-19-2009, 05:58 PM
snostyle's Avatar
snostyle snostyle is offline
Vehicle: 2005 Dodge Ram 1500 Quad Cab
snostyle is on a distinguished road
The earlier Ram's don't have coil over front suspension
It's better to live one day as a Lion than a thousand years as a Lamb
Old 06-19-2009, 07:31 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Might be because of the torsion bar being tweaked a bit tighter than it was.
Old 06-19-2009, 09:02 PM
Rep:62
You are correct...... That is where my YEP answer came from. I was agreeing to what he had already stated: "is the bounce because my oem shocks are now extended too far with the new ride height? and if so would a taller shock alleviate the problem?"
Turning the torsion bars up is like putting concrete at the base of your shocks.....I had a Dakota that I did this to and the ride was horrible after....Longer shocks helped out because they have the travle needed. You will be fine once your new longer tubes are installed.
Old 06-22-2009, 08:31 AM
Smile the shocks helped!
...i installed a set of rancho rs5000 with more travel yesterday and it was a dramatic change to what it was before. thanx for the advice
