Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 06-19-2009, 10:50 PM
tomdatermite tomdatermite is offline
Engine: 1999-2001 359ci (5.9L) Cummins ISB 24-valve Diesel I6 230hp 450lb/ft (manual), 215hp 420lb/ft(auto)
tomdatermite is on a distinguished road
Default Starting a 5.9 diesel
I have a 2002 Dodge Ram 3500, 24V 5.9L turbo, I bought new. A week ago sounded like the starter was getting ready to go. Hence the "grinding" sound made by a starter. I replaced today with a brand new starter not a reman. Its still making that same grinding sound ( abt 5-10 sec ) before actually starting. The batteries are abt 2 years old. Could it be a bad new starter, battery or something else??? It has 171,000+ miles on it. Appreciate any ideas here. Thanx
Old 06-19-2009, 11:24 PM
boostjunkie1's Avatar
boostjunkie1 boostjunkie1 is offline
Vehicle: 2008 Hemi Ram
Rep:62
boostjunkie1 will become famous soon enough
Well the fact that it is actually starting is a good thing ...... Yes you could have got a bad starter....It actually sounds to me (Reads to me) like a bad connection. If the truck is turning over for 6 to 8 seconds before starting you are not getting enough fuel a low rpms to start that beast. You need to check the fuel pressure after the Fuel Injection Pump. Batteries could also be a figure expecially if you are waiting for the wait to start light to go out. If they are close to dead and your alternator is the only thing keeping them alive you will not have the cranking amps needed to spin it over fast enough. I cannot hear what is going on so from my point of view that is what I got. The High Pressure Fuel pumps on the 2nd Gen 24 valves are bad to go out. ANd most go out slow like that and cause the same issue as you are having........Weak batt's and a weak pump can equal your issue........Could also be the crank positioning sensor........I think there is a flash for that
Old 06-21-2009, 06:53 AM
Forgot to mention the fuel injection pump, dealer replaced back in March this year...... Could also be the crank positioning sensor........I think there is a flash for that.......
Where is this located and a flash is what??
