Shaking when breaking at higher speed - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 06-20-2009, 09:47 PM
bigbass19 bigbass19 is offline
Vehicle: 2001 Dodge Ram 1500 Sport
bigbass19 is on a distinguished road
Default Shaking when breaking at higher speed
Ok guys, here is my first question for you. Picked up a nice 01 dodge ram 1500 sport. 5" lift, tires are 305/70/16. I have expected to have to do a little bit of work on her. First thing I want to do is find out about the breaks. When breaking when going up to 45 she's fine. When I get going any faster and start breaking she starts shacking/jumping pretty bad is I stay on the breaks. If I pump until I slow done to about 45 then shes fine after letting off then breaking again. What is causing this? Thanks for the help.
Mike
Old 06-20-2009, 10:40 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
Maybe the rotors are warped?
Old 06-20-2009, 11:33 PM
rollin rollin is offline
Vehicle: 1996 ram
Color: maroon
rollin is on a distinguished road
thats what im thinking is warped rotors
Old 06-21-2009, 02:03 AM
boostjunkie1's Avatar
boostjunkie1 boostjunkie1 is offline
Vehicle: 2008 Hemi Ram
Rep:62
boostjunkie1 will become famous soon enough
You need to look into what is called Death Wobble..........This is due to the high speeds and the loose front end components. Larger wheels and tires help to bring this out in the older Dodges. Do a Google Search on this.....New Bushings, steering stabilizer, nuts and bolts, shocks, .......Be Safe, and it could also be brought on by warped rotors but if they were warped you would feel it at all speeds....Boost
Old 06-21-2009, 09:40 AM
08quadram's Avatar
08quadram 08quadram is offline
Vehicle: 08 Ram Quad 1500
Color: silver
Rep:22
08quadram is on a distinguished road
I second the dreaded death wobble. I've had it on older Jeeps. Mine turned out to be loose u-bolts holding on the axles.
Mike
'17 Ram 1500 Big Horn Crew, 5.7 Hemi, 3.92 axle
"Meddle not in the affairs of dragons, for thou art crunchy and good with catsup" -Doc, IFSJA
Old 06-21-2009, 09:54 PM
I was thinking rotors too. Never heard of the death wobble before. I'll have to look into that. Thanks
Old 06-21-2009, 10:14 PM
I just looked at the death wobble stuff, it doesn't sound like that. From what I saw it is caused by hitting a bump or pot hole. My truck is fine driving, it's just when breaking going any faster then 45. Once speed drops below 45 it's fine....I'm gonna check on the rotors. Any other suggestions?
Old 03-17-2017, 01:04 PM
96Cummins3500 96Cummins3500 is offline
Vehicle: 1996 3500 Cummins
96Cummins3500 is on a distinguished road
I have a wobble when breaking at lower speeds
