Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Place your Ad Here!
Old 06-21-2009, 02:53 PM
scgmc scgmc is offline
scgmc is on a distinguished road
Default Tach jumps 200 RPM-intermittent
I've got a 1998 Dodge Ram 2500 4x4 with the V10 and an automatic transmission. I perform regular preventive maintenance and she's got 145,000 miles. Driving in OD between 55 and 80 mph, sometimes the tach jumps up 200-300rpm with a corresponding rise in engine noise. I never get a Check Engine Light. The truck doesn't surge but sometimes runs a little rough when it happens. Flooring it makes it go away until the next intermittent time it chooses to come back. Dropping it into D and/or tapping the brake pedal(to unlock the torque converter) doesn't change anything. It is NOT dependent on load or climbing a hill. I've added fuel injector cleaner, cleaned the throttle body, changed the plugs, and kept up with all the tranny fluid changes and band adjustments. It has had this problem for 20,000 miles. It may go two tankfuls between occurences. I'm stumped- anyone had this same thing? What's the fix?
Old 06-24-2009, 07:46 AM
Nobody had this problem?
Old 06-25-2009, 02:47 PM
jrallen06QC jrallen06QC is offline
Vehicle: 2006 Ram 1500 QC
jrallen06QC is on a distinguished road
I had the same problem with my Durango. It's an easy fix; it's the throttle position sensor on the throttle body. Chang eit quick because the trans is going in and out of lockup which can damage the torque converter. The part for me was only $65. I would suggest cleaning the throttlebody as well so you may want to get a new seal as well. For my Durango I didn't have to remove the throttle body to change the sensor. To find the problem I had a trans tech and a computer kooed up while driving and we noticed the torque converter going in and out for split second, it had to happen a few times before he actually saw it on the computer because it was happening so fast. After replacing the part everything went back to normal.
Old 06-30-2009, 07:36 AM
Jrallen
Thanks. I could try that. If it's that cheap, it won't hurt to try.
I'm curious, did yours ever give any "Check Engine" lights? Mine never does, and I assumed the TPS was monitored by the engine management computer and would flag it if it sees a problem in this sensor.
Old 07-13-2009, 09:03 AM
Thanks jrallen. The TPS seems to have fixed it. Time will tell. As a bonus now the cruise control works much better, no hunting. In my case it was $30 for a Borg Warner part. Thanks for helping a brother out.
Old 03-20-2010, 09:12 AM
With my occurance no lights no warnings. I did some reading on the subject and had a service tech with a computer ride with me to figure out the problem; he even missed it with the computer because the change was happening so fast.
