Old 06-22-2009, 06:13 PM
jbeanes jbeanes is offline
jbeanes is on a distinguished road
Default Sun Visor falls down on 2002 Ram
The drivers side sun visor on my '02 1500 4WD Ram will not stay up. This is the version with no mirror or light. It simply has the slot for putting a map or some minimal paper work....and it will extend when using in the side position.
Does this visor have an internal collet of smeomthing like that that I can adjust to make it tighter and stay up??
Thanks,
JB in NC
Old 06-22-2009, 08:19 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
Wish I could help, at present I have velcro holding mine up.
Old 06-22-2009, 11:51 PM
Ramblerman's Avatar
Ramblerman Ramblerman is offline
Vehicle: 2002 Dodge Ram Quad Cab 4x4
Ramblerman is on a distinguished road
I have the same exact truck with the same exact visors! My driver's side visor is very close to being at the point where it will not stay up at all. Right now it stays up most of the time, depending on it's exact position. As far as I know, unless you want to snug it up by putting tape around the snap-in part near the mirror, you would have to buy a complete new visor assembly. My truck has 98,000 miles, so I guess it deserves a little sagging.
Daniel
Silver 2002 Dodge Ram Quad Cab 4x4
Old 06-22-2009, 11:54 PM
Check the spot where the visor arm goes into the fixture at the headliner. You may find some screws there that just need to be tightened a bit. I suspect you'll find some set screws there.
Old 06-23-2009, 07:49 AM
My truck has 136K miles so I guess I'm not too disappointed either. Thanks fellas.
Old 06-23-2009, 08:54 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Isn't there usually a spring on the backside of the assembly that bolts to the roof that applies tension to the arm? I am not sure on the new trucks. I know on my older ones I would put washers behind the spring to apply more tension to keep them from dropping down on gravel roads.
Old 06-29-2009, 12:23 AM
davsram's Avatar
davsram davsram is offline
Vehicle: 2003 Dodge ram 2500 HEMI
Rep:14
davsram is on a distinguished road
Send a message via Yahoo to davsram
Default visor
same issue with mine i use a paper clip works well
Dave, Minneapolis M.N
Old 08-03-2009, 06:50 AM
HotRodQuad HotRodQuad is offline
Gender: Not Specified
Vehicle: 2004 Dodge Ram 1500 QuadCab
Trim Level: SLT LoneStar Edition
Color: Brilliant White
Rep:12
HotRodQuad is on a distinguished road
Default Sun Visor
Daniel
I have a 2004 QuadCab. My passenger side visor was falling down.....it wouldn't stay up at all. I went to the dealer on Friday and had it replaced.....for a cost of $122!! The darn thing doesn't even match the original one. The new ones have some sort of plastic trim around the little bar that snaps into the support clip. The original is all cloth. Also, the seltbelt warning tag is slapped on near the top, close to the middle of the visor! This would be okay if I didn't have custom covers for these warning signs. The new visor looks really cheap and I'm upset that the warning sign is no longer at the bottom outside position. I paid a lot of money for those custom covers. I'm tempted to take it back to the dealer, have it removed, and get a refund......I had them put the old one in the backseat, but the mechanic put his greasy fingerprints on it......so I may be screwed. I'm just really unhappy with the whole experience. I usually get treated really well at the dealer, but this time really sucked. BTW, my dealer is Huffines Dodge in Plano, TX.
Old 11-04-2011, 02:47 PM
SteepleJack's Avatar
SteepleJack SteepleJack is offline
Vehicle: 2002 Dodge Ram 1500 Crew, 4x4
Color: Garnet
SteepleJack is on a distinguished road
I have the same problem with both visors...I have been thinking about it and living with it for a while. I just looked on LMC and the sell visors of course...but they had a not that suggested you "Bend the rod slightly to tighten the sun visor on the rod". I will be trying this! I can believe I did not think of this as it is how I fix door that are not level and open or close by themselves. Bend the hinge pin for added friction...wha-la. I will let you know the reults...when I actually get around to it.
~ SteepleJack ~
'02 1500 - Quad Cab - 5.9L - 4" Tough Country - 17x10s w/ 315/70's
Old 11-21-2011, 12:33 PM
Color: Garnet
It helped some but not enough to be the final solution...still going to replace them.
~ SteepleJack ~
