Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
United Radio
Old 06-22-2009, 07:41 PM
fast929rr's Avatar
fast929rr fast929rr is offline
fast929rr is on a distinguished road
Default 04 ram 1500 vibration
im getting a vibration when i first take off then againg when i put on the brakes at low speed dont think its the rotors because its doing it when i take off maybe a problem with the drive shaft truck has 75000 miles on it
Old 08-25-2009, 08:14 AM
eric1238 eric1238 is offline
eric1238 is on a distinguished road
I have a similar problem. When I first accellerate from a dead stop, there is a vibration in the rear end. Did you ever find a resolution?
Old 08-25-2009, 09:03 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Had the same problem w/ my 04. Had the dealership turn down the rotors (which isnt easy cause rotors are very thin for as big as they are). Also had the tires rotated and balanced. Fixed problem, but you gotta be careful driving through water with em. My suggestion is instead of spending the money on turning em, get some aftermarket drilled/slotted rotors w/ceramic pads. Should last for a long time. Thats my plan when I need to change my brakes again
