Old 06-23-2009, 01:02 AM
Ramblerman's Avatar
Ramblerman Ramblerman is offline
Vehicle: 2002 Dodge Ram Quad Cab 4x4
Ramblerman is on a distinguished road
Default Air hissing noise under engine/transmission!
Hi all,
I just bought my '02 Quad Cab 4x4 with the 4.7 V8 and 5-speed less than a week ago! I love this truck!!! Great forum too! I was curious about something though. Whenever the engine is running, there is a very loud hissing, or whooshing, noise coming from under the truck around the middle of the engine/transmission area. When I turn off the engine, the noise does not just stop, it continues to sound like it is leaking for a couple of seconds.
Is this possibly something to do with engine vacuum? Is there something under there that would cause this? The truck runs great, and I have had other cars with vacuum leaks and usually they do not run that well!
Thanks in advance,
Daniel
Silver 2002 Dodge Ram Quad Cab 4x4
Old 06-23-2009, 01:04 AM
What you are describing might be a small exhaust leak or a pinhole in the catalytic converter. There are no vacuum lines there. I'd inspect the exhaust.
Good luck and let us know what you find!
Old 06-23-2009, 01:26 AM
Ramblerman's Avatar
Cool, thanks! That sounds logical. I will get under the truck in the next day or so and see what I can see!
-Daniel
Old 06-23-2009, 01:34 AM
While you are under there, Daniel, check all around. Look for the obvious, such as an exhaust flange that is loose, a loose fuel evap cannister hose, etc...
Good luck!
Old 06-23-2009, 09:59 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
He's the man right there ^^^ Great suggestions sir. I wanted to add maybe checking around the airbox on top of the intake. Perhaps the previous owner had a CAI, put the stock airbox back on before selling it, and didn't get a clamp tight enough?
Old 06-23-2009, 10:27 AM
4doordodge4life 4doordodge4life is offline
Vehicle: 2003 RAM 1500
Color: white (with black parts)
Rep:40
4doordodge4life is on a distinguished road
Send a message via AIM to 4doordodge4life Send a message via MSN to 4doordodge4life Send a message via Yahoo to 4doordodge4life
i have the same thing except its coming from my intake!, 164,000+ miles on it was a scott's lawn truck (so guaranteed no mods) what could THAT be?
Old 06-29-2009, 02:42 AM
Ramblerman's Avatar
Good luck!
You were right, Maddog! I finally got a chance to look under my truck today. It turns out that one of the "coupler" hoses going to the fuel emissions canister under the truck had a very nice crack in it. In less than 5 minutes I replaced that little rubber hose (the ones in between the non-repairable plastic emissions tubing) and the hissing was gone! Woohoo! The idle actually seems a bit higher too, which I guess makes sense!
Thanks,
Daniel
Old 06-29-2009, 10:46 AM
chithead's Avatar
Rep:2078
I am telling you, he is the man!
Old 06-29-2009, 11:22 AM
Ramblerman's Avatar
You were right! I bow to Maddog for knowing the cause of the problem, and I bow to Chithead for knowing that Maddog would know the cause of the problem!
Daniel
Old 06-29-2009, 07:21 PM
Sparky's Avatar
Sparky Sparky is offline
Vehicle: '06 Ram Quad Cab HEMI
Color: FLAME RED
Rep:23
Sparky is on a distinguished road
Maddog looks like you got a following, but they are both Daniel how do you tell them apart? JK
