Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 06-24-2009, 01:32 PM
anticommander anticommander is offline
anticommander is on a distinguished road
Default Air Condition on '96 1500
I noticed that my AC wasnt actually blowing cold air so i figured i would try to recharge the system. I connected the hose and read the pressure but it seemed to be just fine. I did notice that the compressor would turn on and the pressure would drop to about 20 PSI then the compressor would turn back on and the pressure would rise to abou 50 PSI.
Is the compressor supposed to be doing this?
Am i supposed to have a consistent reading instead of fluctuating between 20 and 50 PSI?
What other things could be causing this?
Old 06-24-2009, 10:51 PM
jjtroutbum's Avatar
jjtroutbum jjtroutbum is offline
Vehicle: 1996 RAM1500
Trim Level: SPORT
Color: BLACK
Rep:17
jjtroutbum is on a distinguished road
Me to tagging along for more info.
Old 06-25-2009, 09:41 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Sounds like the system may be a bit low. According to a suggestion from an automotive A/C sight, the PSI of the system should be about equal to the outside air temperature when running. Can you see any fluid or foaming in the sight glass? May be some moisture in the system causing the pressure change.
Old 06-26-2009, 12:38 AM
well i went back out and just opened the can all of the way and i saw the compressor engage consistently and the recharge can started to get cold in my hand, and now i have cold A/C. I guess it was just patience
Old 06-26-2009, 09:41 AM
chithead's Avatar
Rep:2078
Well that is good news! Gotta have the cold air this time of year.
