Old 06-27-2009, 12:39 PM
cptsopiens's Avatar
cptsopiens cptsopiens is offline
Vehicle: 2009 Dodge Ram 5.7Hemi 4x4 CC
Trim Level: Bighorn Package
Color: Light Graystone
Rep:14
cptsopiens is on a distinguished road
Default Air Helper kits
I am going to have an air helper kit installed on the rear suspension of my 2009 Ram 1500 this week. I am pulling an 8,000 lbs camper and my rear end is squatting about 3 inches (measured over the wheel well). Does anyone have any experience with this? I think I ordered the Firestone bladder type, but I am wondering if the '09 requires the kind that inflate within the coil springs? I guess I'm not sure what Dodge ordered for me until it comes in. I just want it to work. Any precautions or advice would be greatly appreciated. (i.e. is it best to hook up the trailer and then inflate? or vice versa?) I will probably have to have my camper hitch adjusted again (3rd time).
I'm guessing the link coil suspension has it's draw backs. I probably have about 800 lbs of tongue weight on the truck and I wonder if it would squat that much with a traditional suspension. I sure like the ride though
2009 Dodge Ram 1500 5.7L Hemi, 4x4, Crew Cab, 3.92 Axle Ratio, Bighorn Package, Tonneau cover
Old 06-30-2009, 10:16 AM
kcr9220's Avatar
kcr9220 kcr9220 is offline
Vehicle: 09 Dodge Ram 4x4
Color: Inferno Red
Rep:16
kcr9220 is on a distinguished road
Send a message via Yahoo to kcr9220
Don't have a clue, but if you would, please keep us updated as to what you have installed on your Ram.
Old 06-30-2009, 12:26 PM
Blackzilla's Avatar
Vehicle: 2009 Reg Cab S/B 4X4
Trim Level: Sport/SLT
Color: Black Pearl
Rep:199
http://www.airliftcompany.com/ try these there using these.
Old 06-30-2009, 12:30 PM
Blackzilla's Avatar
Color: Black Pearl
Rep:199
sent ya pm........
Old 06-30-2009, 08:53 PM
jamesb0 jamesb0 is offline
Vehicle: 2006 Ram 2500 Quad/ SB / 4x4
Color: Flame red
Rep:57
jamesb0 will become famous soon enough
Bad news , They didn't design the 09 1500 for towing or hauling as a major requirement. Wish you best of luck with you effort.
Old 07-02-2009, 02:02 AM
I push the skinny pedal
Rep:3277
most likely it will be in-spring bags as your hitch is mounted to your frame. a frame/box lift wont do any good unless you are running a 5th wheel hitch.
I use airlifts regularly on my '08 f-350 Superduty for hauling bulk air trailers (12,000lbs) the tongue weight is ~900lbs and barely under the DOT regs for pintle hitches. Mine has dual firestones at the shocks, and the ride is better. levels it about 4.5" but still a mother to haul.
also, will you be running a continuous compressor or just the gas station specials? the compressor is really handy if you work in the cold as you have leaks no matter what but does need to be plumbed and enables air-brake set up as opposed to electro-mag breaks on the trailer.
Some cautions: check fittings regularly when hauling heavy loads as they begin to leak (keep a spray bottle with soap and water). if you're running the pump it up and go style, then make sure you have a heavy duty compressor that plugs in if you start to lose air to refill on the fly, else you can overstress one side and it isn't a pretty picture when your bag goes from the unbalanced weight. (new bag, downtime, requires re-alignment, not to mention almost wiping out half a barn...)
And if you're hauling weight like that with your 1500, definately try to invest in a tranny temp sensor, DON'T rely on the dummy light as there's already a problem.
oh, and recommend hitching up then inflating so you can level it with the load.
hope it helped and good luck
Kurtis
Old 07-04-2009, 01:54 AM
cptsopiens's Avatar
Rep:14
Thanks for the input guys! Yes Jamesb0, the Ram 1500 may not be the daddy of towing, but it will meet my needs and I am impressed so far.
Thanks CdnoilRam for the input. I got my Air Lift 1000 installed yesterday, and drove 220 miles with camper in tow today. I have a pressure gauge installed in my dash and I can add or subtract air anytime, which is cool. The manual recommends inflating first, then adding the payload, so that is what I did. The reason for this is to make sure the bladders seat well in the coil springs, and then adding the trailer afterwards prevents severe squatting. Payload is payload, so it still brings the truck down a little, but not nearly as much as before and it is riding level. It looks really good, IMO, even though a 30' travel trailer dwarfs the half-ton Ram. It really makes the truck look like a beast pulling all of that. The airlift kit really stiffens up the suspension, and to me it feels better pulling and the ride is fine since I'm on interstate. Also, I can see my transmission temp at anytime by selecting it in the heads up display on the dash. I went over some major mountains in MT today and it never gets over 1/2 way on the temp gauge. I don't remember the actual degrees.
Now my question is the best way to determine GCWR. My GVW is 6800 and the towing capacity is 8500, so is my GCWR 15,300 lbs? I have read some confusing stuff on determining this value (such as not adding in my driver weight up to 150lbs), but try a search and you simply won't find this value listed anywhere. The Manufacterer's certainly don't list it. I weighed in on the scales today at 13,800 lbs without my wife and kids in the car (225lbs) so I think I am in the ballpark regarding GCWR. Any thoughts?
p.s. I'll send some picks when I get them downloaded. I also got my sweet Leer cover yesterday, all in time for my trip to MN!
Old 07-23-2013, 02:39 PM
cptsopiens's Avatar
Rep:14
Default Dead airbag
The Firestone airbags lasted three years, then leaked and had to be replaced. I had to go to the dealer 4 times for them to get the new ones right. I had problems with none filling, then one filling, etc. now they seem to be working great. They said the Firestone ones had problems so they used a new brand, but I don't remember the name. I hope these last a long times as they cost $495. I have heard of others with bags lasting 8 years. I don't think I'll replace them again at that price. My next truck will be a 3/4 ton, unless I can downsize my camper a bit, but even then the 1/2 ton might squat with a heavy tongue weight.
