Old 06-30-2009, 04:53 PM
kineticenrage kineticenrage is offline
Vehicle: 2005 Ram
Rep:17
kineticenrage is on a distinguished road
Default yet another CAI question
before i owned my ram i was real big into the import scene and learned that a cold air intake is all basically the same thing it's just the filter that you put at the end. what my question is, if i were to put a K&N filter in the stock air box, will that be sufficient or is the stock air intake system just to restrictive?
Old 06-30-2009, 10:24 PM
Leadfootluke Leadfootluke is offline
Vehicle: 1998 Dodge Dakota
Rep:276
Leadfootluke is a jewel in the roughLeadfootluke is a jewel in the roughLeadfootluke is a jewel in the rough
The Hemi-Hat itself if restrictive. So a drop-in filter can only do so much.
A performance intake itself depends on the ability to allow unrestricted flow to the engine. The basic kits are 4" tubing with a cone filter and maybe a heat shield, which has been looked into as being restrictive in itself (as it turbulated and inpeeds on airflow TO the filter).
Thats why the BFI from AirFlow Innovations sticks out. The filter is a 6" base and sits upon an intake with 6" conical construction. It allows for incredible flow and power, and increase the growl of the engine by LARGE volumes. So yes, an aftermarket intake, and a good one at that, will be a great benefit over stock or just a drop in.
Old 07-02-2009, 12:39 AM
I push the skinny pedal
Rep:3277
most stock boxes use the ever lovely flat pad filter which doesn't have a very large surface area, the aftermarket CAI with cone filters have more breathing area, but are still stuck in the same air intake volume problem. A solution is to get a FUNCTIONAL ram air hood which moves air into your air box based on how fast you go (faster = better...go figure). off the line, not much of a benefit, but at speed, it comes into its own. Otherwise you do have more airflow due to less restriction which is still a plus.
Kurtis
Old 07-02-2009, 02:06 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
my first homemade was with stock airbox with k&n minus the air resonator...I now run the ramhammer (BFI now) and it makes a world of difference..
