Old 07-01-2009, 12:05 AM
rnr127 rnr127 is offline
rnr127 is on a distinguished road
Default Oil not pumping
My oil pressure dropped to "0" and engine began to knock. A day or 2 later when I started the truck the pressure was back up and after a few minutes it began to drop then the engine starte to knock and eventually the pressure went back to zero. I replaced the oil pump with a new high volume pump but still have the same problem. Is there anyone else out there that has had this same problem or knows what is wrong. Please help. 2001 Dodge Ram 5.2 L V8 Magnum
Old 07-01-2009, 03:45 AM
boostjunkie1's Avatar
boostjunkie1 boostjunkie1 is offline
Vehicle: 2008 Hemi Ram
Rep:62
boostjunkie1 will become famous soon enough
Silly question but you do have the proper amount of oil in the engine right???? Sounds like the truck will prime at initial start up but then lose oil pressure.........You may have some gunk in the oil valleys / plumbing that needs to be flushed out.......Get some SEA FOAM....Follow the directions.......clean the crank case out a couple times........Also make sure that your Battery and Alternator are in good order. EGR valve need replacement?????? Sending unit gone bad?????
Old 07-01-2009, 03:46 AM
Rep:62
You can also check out AUTO RX...........This stuff really works!!!!
