Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Recalls and TSB's.
Old 07-06-2009, 12:22 PM
redram77 redram77 is offline
Vehicle: 04 1500, 06 2500 diesel
redram77 is on a distinguished road
Default egr valve
hello, I have an '04 ram 1500 with 5.7l, and am getting a code for the EGR valve. it looks simple enough to replace but I heard the stealership must flash the ecm on the truck immediatly after replacement. what is the reason for this? and has anyone replaced one themselves with out flashing the ecm? did it work ok?
I believe there was a TSB for this problem, what is the companys or dealerships responsibility for TSB's?
thanks in advance
Old 08-10-2009, 11:51 AM
ramit04's Avatar
ramit04 ramit04 is offline
Vehicle: 2004 Dodge ram 1500
Rep:74
ramit04 will become famous soon enough
my check engine lght came on today! went and had it checked and they said it was egr
Old 08-12-2009, 10:38 PM
Dooley's Avatar
Dooley Dooley is offline
Vehicle: 2005 Dodge Ram 1500 Quad Cab
Rep:15
Dooley is on a distinguished road
Mine check engine light's been on for a while now, code for EGR valve. Already have the part, waiting for a couple of free hours so I replace it. Should be pretty straight-forward, and I'd say any OBDII scanner/flasher should be able to reset it.
Aldo "Dooley" Venturacci
2005 Dodge Ram 1500 // 2004 Kawaskai Vulcan 1500
Old 09-24-2009, 03:36 AM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
I've got a buddy who replaced his own EGR valve on his '04 Hemi Ram and has had no problems. No flash needed.
Old 09-24-2009, 08:35 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
I replaced mine, no flash required
Old 10-04-2009, 08:52 AM
cmc cmc is offline
cmc is on a distinguished road
Default egr valve
I have a 2005 ram 1500 5.7 engine. It will not start up without having to give it gas. Driving at about 15 mph, between 1100 and 1300 rpm, engine surges. Check engine lite came on. Is this a symtom of needing an egr valve????
Thanks in advance.
Old 10-04-2009, 09:20 AM
It could be . But it could also be a multitude of other problems . Is your check engine light on ? If it is get the code out of it and lets diagnose that first and see what happens . Let us know . Don't forget to go to the newbie section next and introduce yourself . Get your official greeting . Talk to ya soon . Tom
Old 10-12-2009, 10:52 PM
BIG BOY BLUE's Avatar
BIG BOY BLUE BIG BOY BLUE is offline
Vehicle: 2003 DODGE RAM QUAD CAB
Color: ALTANTIC BLUE
BIG BOY BLUE is on a distinguished road
About 2 months ago i had similar problems to some of you guys above. my truck had a rough idle at stop lights and was tearing up my gas mileage (even driving like an old lady)and had the check engine light on but the only code it gave was the EGR Valve.The mechanic at the Chevy dealer i work at said it could be a number of things but we started simple we changed the IAS (Idle Air Speed) Motor which solved the idle problem and the EGR was replaced but to no resolution. Im still dealing with the EGR problem 2 months later!!! When the check engine light turns off i have crappy gas mileage and my power dissapears but when its on i have normal gas mileage and normal power. You dont understand how frustrating this thing is! i dont know what to do anymore! even the mechanic at the DODGE dealer i took it to was scratching his head and couldnt diagnose my problem. all he could say is try replacing the EGR but the thing is ive bought 2 new valves in the past couple months! at $40 each time to not even fix my problem doesnt exactly make me the happiest guy in the world. im kinda happy to know im not the only one having EGR code problems. My mechanic has an idea on what to check next so if i hit the problem i'll be sure to be everyone here know immediately.
Old 10-13-2009, 09:00 PM
I push the skinny pedal
Rep:3283
Keep us in the loop, I have the same problem. My check engine light is my best friend these days. Sad but true...
Kurtis
Old 10-14-2009, 10:05 AM
Trim Level: Custom
Rep:1648
Have you or your mechanic tried cleaning the return tube from the EGR to the intake?? That is a commonly looked over problem....actually it was what was wrong with mine, but since I was there already, I changed the Valve as well
