Old 07-11-2009, 11:18 PM
bobd70 bobd70 is offline
bobd70 is on a distinguished road
Default 2004 odometer
i have a 2004 ram with 20 inch tires and just recently it came to my attention that the odometer is out of calibration , does anyone know if the odometer is factory set for the smaller tires
Old 07-12-2009, 07:30 AM
RLRambler's Avatar
Color: Inferno Red
Rep:114
The Odometers are calibrated for the size of the "original"wheels on the truck.Chances are somebody replaced them with the twenty inch wheels, hence your problem!
Les.
Old 07-12-2009, 09:40 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
it's an easy fix. you can either use a power programmer to adjust for the larger wheels and tires, or you can go to the stealer and have them recalibrate your speedo and odometer.
the programmer will set you back several hundred bucks, the stealership shouldn't be too much, perhaps a half hour's labor charge....
Exco
Bill
