Cruise Control? "BRAKE" Light. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 07-13-2009, 10:22 PM
wilkinson wilkinson is offline
Vehicle: 1994 Dodge Ram 2500
wilkinson is on a distinguished road
Unhappy Cruise Control? "BRAKE" Light.
My cruise control isn't working at all. I've checked the fuses and relays, all are fine. Also my BRAKE light has been on since I bought the truck. It was painted over, until recently when I noticed a small red light and scratched at it and found it to be the BRAKE light painted over. Also the ABS light is on. Are these all related somehow? Can anyone help me fix atleast the cruise control, I'm headed on a long trip soon, and it would be nice! Thanks!
Old 07-14-2009, 11:37 PM
Sparky's Avatar
Sparky Sparky is offline
Vehicle: '06 Ram Quad Cab HEMI
Color: FLAME RED
Rep:23
Sparky is on a distinguished road
They are related some how, the cruse will not work with the break on.
I would not know where to start looking, maybe someone else will help answer this one.
Old 07-15-2009, 04:12 PM
Zonestar's Avatar
Zonestar Zonestar is offline
Rep:235
Zonestar has a spectacular aura aboutZonestar has a spectacular aura aboutZonestar has a spectacular aura about
The ABS has a bad sensor most likely which will cause the ABS not to function. I had this same problem and it also caused the cruise control not to work.
Old 07-16-2009, 03:30 PM
bnutte bnutte is offline
Vehicle: 2004 Dodge Ram 2500
Color: red
Rep:14
bnutte is on a distinguished road
I'm not sure if this would help you or not. Shortly after I purchased my truck I had an issue with the brake light staying on. The fix was easy by pulling the brake release with hand then pulling up on the brake with foot till it wouldn't move any closer and released with hand while still holding with my foot. My thought for your situation would be if that worked the cruise in turn would. Cruise control usually doesn't work while brake is engaged (as thought by computer i.e. brake light on) as gm owners tried to eliminate daytime running lights.
Old 02-14-2011, 11:32 PM
thechoochlyman's Avatar
thechoochlyman thechoochlyman is offline
Vehicle: 1989 W150 318
thechoochlyman is on a distinguished road
Bad vacuum line perhaps?
Old 02-16-2011, 08:32 PM
Longshot's Avatar
Longshot Longshot is offline
Vehicle: 2007 ram 4x4 5.7 hemi
Trim Level: laramie
Color: red
Rep:104
Longshot will become famous soon enoughLongshot will become famous soon enough
check the brake light switch at the pedal if it's bad cruise wont work
07 Laramie 4x4 HEMI, ATX series Artillery wheels,Nitto295/60/20 terra grapplers,Predator,nerf bars,leveling kit,stainless door, tailgate handles, mirrors,Weather Tech floor liners,Airaid CAI,Flowmaster 40 series exhaust,Extang Trifecta Signature Series Tonneau,electric tailgate lock, vent visors
Old 06-08-2011, 10:24 AM
DHDOGS DHDOGS is offline
Vehicle: 96 Dodge Ram Sport
Color: Blue/green
Rep:26
DHDOGS is on a distinguished road
I have had the same problem. I was told it had to do with the sensor or the computer. I disconnected the positive battery connector for more than one min. as instructed. After the battery was reconnected the lights went out.
Old 08-08-2014, 09:05 PM
mrgreg2 mrgreg2 is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: larime
mrgreg2 is on a distinguished road
2005 dodge ram 1500 abs light and brake light are on as well as my cruise doesn't work. i have already replaced my differential speed sensor with no help.
I also disconnected my battery while changing the speed sensor in the differential.
I also would like to know what the fix is for this issue!
abs light abs, brake, brake light, cruise control
