Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Towing
Old 07-14-2009, 02:49 PM
chris66 chris66 is offline
Vehicle: 2009 Ram1500, 5.7L HEMI
Trim Level: Sport Crew Cab, 4x4
Color: Mineral Gray
Rep:14
chris66 is on a distinguished road
Default Towing issues
Hi Everybody,
Just came back from a trip, towing about 4500lb. The truck handled the load pretty well I would say, plenty of power, so I am quite happy here even though it seemed to have . What I didn’t like though, is that the rear end was feeling kinda “springy” to me, bouncing up and down sometimes (at least that was my feeling).
There are no mods on the truck other than few cosmetic ones and adding a canopy. I read a bit about these air bags you can install and I phoned the dealer to see what they think about the problem and if they have any suggestions. First thing they said was to blame it on the hitch equalizer, maybe wasn’t set and adjusted properly, so I am going to have it looked at just for the peace of mind.
Has anyone else experienced similar issues? Is it the hitch equalizer or is the coil springs in the rear suspension? If it’s the springs, will installing the air bags help?
Thanks for any feedback you can provide
Old 07-14-2009, 03:31 PM
MrDodge300's Avatar
MrDodge300 MrDodge300 is offline
Vehicle: 1986 dodge ramcharger
Color: Gray & silver
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
Rep:82
MrDodge300 will become famous soon enough
Send a message via Yahoo to MrDodge300
i have leafs in the rear and i have the same feeling i just think that it is just the extra weight on the suspention but im no expert so i could be wrong
Old 07-21-2009, 06:52 AM
kcr9220's Avatar
kcr9220 kcr9220 is offline
Vehicle: 09 Dodge Ram 4x4
Color: Inferno Red
Rep:16
kcr9220 is on a distinguished road
Send a message via Yahoo to kcr9220
4500 pounds is quite a bit of weight, especially sitting on the hitch. You may have to get some airbags to assist you.
Old 07-21-2009, 07:37 PM
boostjunkie1's Avatar
boostjunkie1 boostjunkie1 is offline
Vehicle: 2008 Hemi Ram
Rep:62
boostjunkie1 will become famous soon enough
Dodge used a couple different spring rates on the new 09's. The TRX's have the heavy duty springs compared to the Sports and Laramie Rams. You can add some Firestone Air bags to the mix and help with the squatting. Or you can order some heavy duty springs for the rear. If you tow only every now and then get the Air Bags.
Old 07-21-2009, 09:57 PM
Air bags or a load leveling/anti-sway hitch is what I'd recommend. The load leveling hitch will spread the tongue weight between the truck and the trailer. They work pretty good!
Any idea what your tongue weight is?
Old 07-21-2009, 11:36 PM
Equalizer bars work greaty . Tie everything together real nice .
Old 08-02-2009, 06:48 PM
norco's Avatar
norco norco is offline
Vehicle: 2006 ram 1500 4x4
Color: blue
norco is on a distinguished road
RideRite aribags are great they will take care of the problem.
06 RAM 4x4 2.5' kit,35" dick cepeks,bushwacker flairs.k/n air,fullmetal bed cover. Bilstin shocks
Old 08-02-2009, 07:36 PM
Blackzilla's Avatar
Vehicle: 2009 Reg Cab S/B 4X4
Trim Level: Sport/SLT
Color: Black Pearl
Rep:199
airbag it.......
Old 01-06-2012, 09:40 PM
BigTJohn's Avatar
BigTJohn BigTJohn is offline
Vehicle: 2012 Ram 2500
BigTJohn is on a distinguished road
I have toweda travel trailer (2) one was 5000 lbs the new one is 5700 lbs. I have not done a tongue weight yet but I do know the Reese anti-sway/load equalizer hitch does make a huge difference. It must be adjusted with the trailer LOADED to normal towing/traveling weight. If not, then you get the up/down feeling like the trailer is pushing you some as you go down the road. Not too bad on level roads but can be deadly in mountains esp. downhill. Get the right hitch and it's all good.
"Life is not too short, just that you are dead for so long..."
Old 01-10-2012, 01:30 PM
emmyshemi's Avatar
emmyshemi emmyshemi is offline
Vehicle: 2014 Ram Bighorn Crew Cab V-6
Trim Level: SLT bighorn V-6
emmyshemi is on a distinguished road
I also have a travel trailer and the rear end was the same way. I installed airlift 1000 air bags to the rear coil springs. The install was easy, and they have solved the problem, 100%. I purchased them from anythingauto.com, and they are well under $100. There is no need for a on-board compressor. I ran the valve stem straight out the back, just to the right of the license plate. It looks like its straight from the factory. It seems that its hard to find something to work as well as you hope it will, these airbags have exceeded my expectations.
How about I put my "carbon footprint" up your liberal ass?
