Place your Ad Here!
Old 07-15-2009, 08:46 PM
mopar02 mopar02 is offline
Vehicle: Dodge Ram 1500 SLT
mopar02 is on a distinguished road
Default P1495 Code problem
Does anyone know what a P1495 code is ? and what needs to be done to fix it?
Old 07-15-2009, 08:55 PM
rpreburn
code if for the leak detection pump circuit you need to replace the ldp leak detection pump. its part of your emisions system and is used by the vehicle to test for leaks hope this helps.
Old 07-20-2009, 03:47 PM
Thanks for the advice. Turns out there was only one of three wires that was not broke.
Old 07-02-2013, 10:31 PM
partsmore partsmore is offline
Vehicle: 2001 Dodge Ram 1500 4x4 5.9l
Trim Level: sport
Color: yellow
partsmore is on a distinguished road
Thumbs up p1495 Leak detection pump - harness, etc.
Please show pictures of the pump, part #'s and wiring harness?
Old 08-07-2013, 03:47 PM
rockyracoon rockyracoon is offline
Vehicle: 2002 Dodge Ram 1500
Color: Gold
rockyracoon is on a distinguished road
I have had p1495 problems myself. Found cracked hose between LDP and canister. Replaced hose and cleared code. Engine light on in about 30 seconds - code p1495. Found crack in pump. Replaced pump, and cleared code. Light back on in about 30 seconds; code p1495. Fuel cap is common source of this, so I replace fuel cap. Cleared code; back to square 1 in the usual 30 seconds. Have checked all vacuum hoses; none missing, loose, cracked, or otherwise damaged. I really can't afford taking it to dealer, so I guess I'll live with it unless someone has an idea out there.
