Smart Choice Cai - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Old 07-17-2009, 01:15 PM
Wombatsxt's Avatar
Wombatsxt Wombatsxt is offline
Vehicle: 03 Ram 1500
Rep:18
Wombatsxt is on a distinguished road
Default Smart Choice Cai
What would be the most cost effective way to add a cai to an 03 4.7 Ram. I really dont see the point of puttin down some plastic almost home depot style pipes for 200$ at the cheapest.. Is there a DIY guide to making one?
Old 07-17-2009, 01:26 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Ooooh I want to see how this turns out...
Old 07-17-2009, 11:06 PM
hokunahooikaika's Avatar
hokunahooikaika hokunahooikaika is offline
Vehicle: 2007 1500 quad cab 4.7L
hokunahooikaika is on a distinguished road
when i had an old suzuki jeep i had a muffler guy bend some pipe for me and we just stuck it to the throttle body and put a filter on the end. i'll see if i can find a pic. honestly it was pretty ghetto so i usualy dont point peepz down that ally unless you dont give a crap about how it looks or about Reliability
2007 1500 Big Horn Quad cab 4.7 Flex 2.5" leveling kit 20" stock rims and tires
Old 07-18-2009, 12:46 PM
Just saw this on Trucks this morning . http://www.spectreperformance.com/#N...RODUCTS.050908
Old 07-20-2009, 02:14 PM
Wombatsxt's Avatar
Rep:18
im not finding anything except a replacement filter, but i was hoppin to find a whole Cai setup, if anything, whats the best size cone filter if i end up makin my own?
Old 07-21-2009, 11:38 AM
SpokaneDodge SpokaneDodge is offline
Vehicle: 2002 Dodge Ram 1500
Trim Level: SLT QC 4x4
Rep:17
SpokaneDodge is on a distinguished road
DIY. Very Easy. SUPER easy. Did mine in a couple hours. With painting and dry time.
Old 07-21-2009, 03:01 PM
mlowney's Avatar
mlowney mlowney is offline
Vehicle: 2006 Ram 1500 quadcab 4x4
Rep:72
mlowney will become famous soon enough
Old 07-21-2009, 03:06 PM
kineticenrage kineticenrage is offline
Vehicle: 2005 Ram
Rep:17
kineticenrage is on a distinguished road
did it make a difference in performance?
Old 07-21-2009, 05:25 PM
Wombatsxt's Avatar
Rep:18
Sweet do you have a guide?
Old 07-21-2009, 05:47 PM
Rep:17
Couldn't tell you HP or Torque changes without a dyno, but at the very least it is running much cooler on the guage and my MPG city improved about half a mile per gallon.
No real need to have a guide.
Use ABS piping, 3 inch. Will need a rubber 3" coupling for connecting to engine. I used 2x 3" long 90degree elbows. Then just measure out and connect the elbows with 3" pipe. Angled the end (going to the filter) downward just a little bit (not more then 10-15 degrees). Peiced it all together and test fitted it, then ABS cemented them together, painted it all with Krylon Fusion textures silver (feels like sand paper).
Bent a peice of metal that had holes run through it, bolted around the piping then bolted to the frame where the air filter box used to be bolted. Picked up a "Specter" filter from the local Schucks (Napa, Autozone, whatever).
On an 03 or newer dodge you will need to move the IAS sensor (has blue wires) into the CAI. Just drill a lil hole in the first elbow (by the engine) and mount it in there. You can then run the oil breather hose into the CAI or just pop a small filter on it (like I did).
Couple more photos:
