Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
MOPAR DECALS
Old 07-17-2009, 05:35 PM
reds reds is offline
Vehicle: 2001 Ram 1500 4x4
reds is on a distinguished road
Cool 3500 mega cab ac problem
I'm hoping someone can help with ac problem
ac blows cold and is fully charged but will not cool down cab
on short trips and takes quite a while to cool off on long trips.
Also passenger vents blow much warmer than than driver side.
I'm wondering if anyone has upgraded fan or had a similar problem
and could give some insight.
History of ac system
it never worked right & it was serviced over ten times by dealer over a 1 1/2 year period. They replaced almost every part in system and removed dash twice till they finally found original leak. Now system holds charge but still will not cool truck properly. Both my son and brother have 5.9l quad cabs and they both have great ac cooling.
I dont know if dealer screwed up something or if mega cab is just to big for existing system. I love the truck with 96000 miles no other problems since new but it would be nice to be cool
thanks
Old 07-17-2009, 05:52 PM
How does it cool when on Max . When on max is when you get your best cooling because it is circulating air from the cab back through the system to be cooled again . It's easier for it to cool already cooled air than taking the air from outside and trying to cool it . When you put it on max , you should hear a duct open (normally under the passenger side of the dash) and hear the fan more easily than if it were pulling air from the outside . Let me know . I'm no a/c man but have been around the block quite a few times .
Old 07-17-2009, 06:00 PM
Thanks for help
Door does open when put on max which increases volume of air but unless I drive at high speed for about 20 to 30 minutes it just will not cool properly
Old 07-17-2009, 07:06 PM
Check and make sure you don't have alot of debris in or around your condensor/radiator area . Have been known to find sometimes leaves stuck between the radiator and condensor which will effect the cooling . Might not hurt to even clean your condensor . Thats what removes the heat from the freon before it returns back to the cab to remove more heat . Make sure all fans are doing their job . Both mechanical and electrical if equipped .
Old 07-18-2009, 07:50 PM
Thanks again
Would like to add drivers side vents blow 10 to 15 degrees cooler than passenger side
Old 07-18-2009, 11:12 PM
ljonesj ljonesj is offline
Vehicle: 2005 Dodge Ram Quad 1500
Rep:14
ljonesj is on a distinguished road
still sounds like a damper door is hung somewhere maybe some of the heater is leaking heat through the vents as coolant always runs through the heater core
Old 07-19-2009, 12:00 AM
Thats a posssibility . Don't know if it's still cable operated or motor driven .
Old 07-19-2009, 09:31 AM
1997ram's Avatar
1997ram 1997ram is offline
Vehicle: 1997 RAM 1500
Color: BLUE
Rep:14
1997ram is on a distinguished road
what year and what motor do you have i have alldata. i can look up the info. and maybe send you a photo of the ac comp for the doors.
Old 07-19-2009, 10:01 AM
Wondering if the blend air door is cable or motor controlled on a one ton mega cab .
Old 07-19-2009, 10:11 AM
Rep:14
probably motor but the door could freeze and the motor makes the sound and u hear the clunk but it actualy never moved
