Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 07-19-2009, 11:13 AM
DesertDog's Avatar
DesertDog DesertDog is offline
Vehicle: 07 Ram Mega Cab 4x4
Color: Black metalic
Rep:37
DesertDog is on a distinguished road
Send a message via Yahoo to DesertDog
find out anything new on yur ac prob reds
alot of good info did yuh try any yet
simple math first
clear yur debri if any from the cooler fins
you can usually stick a small pin in the drain hole of the condensor , if its not draining , it will be harder to cool, mine drains like the water faucet was left on.
then check yur damper doors like jones said could be hangin up
preventive maintenance......
best of luck
Old 07-19-2009, 01:24 PM
reds reds is offline
Vehicle: 2001 Ram 1500 4x4
reds is on a distinguished road
Thanks it is a 2006 with 5.9L diesel
Old 07-19-2009, 02:54 PM
The diverter valve in the airflow control box might be stuck or freezing up. One other possibility is that the higher the humidity, the longer it takes to cool down. Also, check and see how much ice is on the compressor to firewall lines. It may be freezing up in that circuit as well.
