Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
ZDOG
Old 07-19-2009, 10:44 PM
96BlkRam1500 96BlkRam1500 is offline
96BlkRam1500 is on a distinguished road
Default clunking steering wheel/gas pedal
ok so i needed ball joints really bad. i put in ball joints upper and lower and saw that my steering shock needed to be replaced so i did that. i also replaced my tie rod end at the pitman arm. the truck drives amazing (getting aligned tomorrow) but on turns with bumps when going slow (and even when going fast, although not as often), i feel clunking at the steering wheel and gas pedal. seems like a hammer is tapping the steering column and foot pedals. it is a stick and sometimes the clutch pedal clunks too. maybe a frame mount? i checked the steering column and doesnt seem abnormal. im clueless right now.
Old 07-21-2009, 09:48 AM
anyone????
Old 07-21-2009, 11:00 AM
ljonesj ljonesj is offline
Vehicle: 2005 Dodge Ram Quad 1500
Rep:14
ljonesj is on a distinguished road
check ur engine and trans mounts and the transfer case mount if its 4x4 they could eb lose or broke and that can transfer to odd areas and check ur rear end and double check everything at the front and ur steering box
Old 07-28-2009, 12:40 PM
I have some spots on the intermediate shaft that look like they are rubbing, bent steering column?
Old 07-28-2009, 02:14 PM
Rep:14
that could be it
