Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 07-20-2009, 03:32 PM
jxoh jxoh is offline
Vehicle: 2005 Ram 1500
Color: Grey
jxoh is on a distinguished road
Default Grinding noise when accelerating from stop.
Hello,
I'm new to these forums. I've recently purchased an 05 1500 hemi. I just noticed that when i'm accelerating from stop, there's a grinding noise under the truck for about 2 seconds and once i'm up past 20mph the noise goes away.
Does this sound familiar to anyone?
Thanks in advance.
-j
Old 07-20-2009, 06:22 PM
DesertDog's Avatar
DesertDog DesertDog is offline
Vehicle: 07 Ram Mega Cab 4x4
Color: Black metalic
Rep:37
DesertDog is on a distinguished road
Send a message via Yahoo to DesertDog
have you check the condition of the rotors or rear drums if aplicable,
grinding ? can u get it to grind in reverse, does it chatter wen it grinds,
does it grind all the time,
grinding ? as in tearing metal or like as in an aluminum can ripping open ,
wut about turning does it click wen u accelerate ?
Old 07-22-2009, 11:54 AM
Color: Grey
you might be on to something with the rotors. The noise is like metal rubbing against each other. it doesn't chatter. just rubs for like 2 seconds and the truck is going, the noise goes away. only happens in drive from stop. i accelerate, makes the rubbing noise for 2 seconds, and it goes away. I hope it's as simple as warped rotors or worn pads and not a problem with something major like the transmission.
thanks again for the insight.
Old 07-22-2009, 02:23 PM
MrDodge300's Avatar
MrDodge300 MrDodge300 is offline
Vehicle: 1986 dodge ramcharger
Color: Gray & silver
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
Rep:82
MrDodge300 will become famous soon enough
Send a message via Yahoo to MrDodge300
is it a 4X4 or no cause it could be the diff, thats the prob my friend is having with his dakoda
Old 07-22-2009, 11:07 PM
Color: Grey
it is a 4x4. how did your friend come the conclusion it was the differential?
Old 07-23-2009, 10:22 AM
MrDodge300's Avatar
Rep:82
i laid under it while he pulled away (im not by any means promoting this in any way)
