Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 07-23-2009, 12:52 AM
Gofish Gofish is offline
Gofish is on a distinguished road
Default Dodge Ram 1500 air flow problem
Hello folks,
I have a 2006 Ram 1500 that has an air flow problem. I cannot re-direct any air out the vents regardless of which position on the switch I select. I either have a switch problem or something is blocking the vents. I have read about similar problems involving the recirculation door which is above the blower motor causing some problems. Has anyone else run into this before? I would like to get this fixed with a permanent solution so that this doesnt happen again. If this is a know problem what are my chances of getting the dealer to pay for it do you think? Slim to none? I am out of warranty now and not looking forward to a $500 bill if I can somehow get around it.
Thanks for any input...
Old 07-23-2009, 01:36 PM
bigredram bigredram is offline
Vehicle: 2003 2500 4x4 hemi
Color: poppy red
bigredram is on a distinguished road
I'm having the same prob, mostly in the winter, and it is the "door" you were speaking of. I would bring it to an auto A/C shop instead of the dealer, may be a little less expensive
