Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Dodge Ram Decals
Old 07-24-2009, 12:28 AM
chris66 chris66 is offline
Vehicle: 2009 Ram1500, 5.7L HEMI
Trim Level: Sport Crew Cab, 4x4
Color: Mineral Gray
Rep:14
chris66 is on a distinguished road
Default Heavy duty transmission oil cooler
Anyone out there can tell how does a heavy duty transmission oil cooler looks like? maybe some measurements or any other means to tell it from a regular cooler?
Mine is about 4" tall, 1" thick and runs about the same length as the radiator.
Thanks
Old 07-24-2009, 05:56 AM
team1320_hemi's Avatar
team1320_hemi team1320_hemi is offline
Vehicle: 2004 Dodge Ram 1500 Hemi
Color: Dark Grey
Rep:28
team1320_hemi is on a distinguished road
Send a message via AIM to team1320_hemi Send a message via Yahoo to team1320_hemi
im interested in this to. i tow a lot and need to invest in this. mines a 04 hemi..
Team 1320 est. 1996 / 2004 Dodge Ram 1500 Hemi Qd Cab / 1992 Honda Civic 2.6L All Motor Race Car
Old 07-24-2009, 08:04 AM
HEMILANCER's Avatar
Vehicle: 09 Dodge Ram
Color: deep water blue
Rep:85
a heavy duty cooler is any cooler not in the radiator. See the factory cooler is built into the radiator thus the tranny fluid is liquid cooled. a heavy duty cooler is usually added to the existing cooler and further cools the fluid using air. the next way to cool the fluid further would be to hold more; IE a deeper pan. not sure if those are available yet though.
Too many mods to fit here!
Old 07-24-2009, 08:17 AM
MDM MDM is offline
Rep:13
MDM is on a distinguished road
My 09's window sticker lists "Heavy Duty Transmission Cooler" as a standard feature. Is this something different?
Old 07-24-2009, 05:44 PM
You can buy the additional (heavy duty cooler) from the dealerships parts dept . Nice piece , have installed several .
Old 07-25-2009, 09:49 AM
Mcguinness's Avatar
Mcguinness Mcguinness is offline
Vehicle: 2009
Trim Level: ST Quad cab Hemi
Rep:28
Mcguinness is on a distinguished road
Ah very interesting.
It is also standard on all 09 rams.
Old 07-25-2009, 10:58 AM
Any Dodge with the towing package will have the trans cooler which is a separate unit mounted down low in front of the radiator. You may see two coolers there...one is for the tranny, the other is for the engine oil.
I don't know if they sized them differently from 1/2T to 3/4T or 1T sized trucks. One way to determine that is to find one of each (maybe at the dealer lot) and measure them. Another way is to call the parts department and see if there are three different part numbers for a 1/2T, 3/4T and 1T transmission cooler. I would assume that as you go up in towing capacity, the coolers get larger.
Old 12-13-2010, 11:30 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
Here are two links for deep and deeper transmission pans. If you look under your truck you may need to have an exhaust shop move your driver to passenger side exhaust cross-over some for it to fit. The way Dodge routed it from the factory is really close to the pan. I did mine to give me the option and I had a custom y-pipe (see pics) put in at the same time.
http://www.yourcovers.com/transmission_pans.html
http://www.mag-hytec.com/store/index...74b0d795cbff62
