Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 07-24-2009, 11:15 AM
MrDodge300's Avatar
MrDodge300 MrDodge300 is offline
Vehicle: 1986 dodge ramcharger
Color: Gray & silver
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
Rep:82
MrDodge300 will become famous soon enough
Send a message via Yahoo to MrDodge300
Question Metalic click
when im driving there is a metalic click from my wheel i thought it was the breaks but when i took every thing off and rotated the hub it was still there
Old 07-24-2009, 01:26 PM
I push the skinny pedal
Rep:3308
does it happen on striaght drives, or just corners? I had a loose sway bar (worn bushings) that used to click on any sort or bump or corner.
Kurtis
Old 07-24-2009, 01:56 PM
MrDodge300's Avatar
Rep:82
if the wheel is moving it clicks
Old 07-24-2009, 02:51 PM
Sparky's Avatar
Sparky Sparky is offline
Vehicle: '06 Ram Quad Cab HEMI
Color: FLAME RED
Rep:23
Sparky is on a distinguished road
I would think a nail or rock in the tire. It will click every time the nail/rock hits the pavement. If the nail is still in there leave it in and get it repaired, because you will not loose air until the nail is removed.
Old 07-24-2009, 03:09 PM
MrDodge300's Avatar
Rep:82
it aint the tire cause like i said i took the tire and the breaks off and manualy turned whats left it still clicked
Old 07-24-2009, 10:59 PM
DesertDog's Avatar
DesertDog DesertDog is offline
Vehicle: 07 Ram Mega Cab 4x4
Color: Black metalic
Rep:37
DesertDog is on a distinguished road
Send a message via Yahoo to DesertDog
u-joint my ram friend,,,,,,,,? actually i have no idea
but that was my first thought , for that was the first problem wen mine went out a clicking noise started,,,, get under there look for rust around the u-joint ends thats a good sign the permanently sealed u-joints grease has failed
or if there is a grease fitting (zert) pump some grease in it and see if the clicking stops
m
ps: also look at the wheel bearing too if they hav never been greased they can click as well , its metal to metal no grease you'll get a clicking
Old 07-24-2009, 11:37 PM
castro's Avatar
castro castro is offline
Vehicle: 01 dodge ram
Trim Level: slt magnum
castro is on a distinguished road
how was the condition of the wheel hub bearing
no i cant help u move lol
Old 07-27-2009, 10:08 AM
MrDodge300's Avatar
Rep:82
idk i dont have the tools to get in there but i will get them tis weekend
Old 07-27-2009, 11:50 AM
Rep:3308
If you removed everything and the hub was still clicking, def sounds like a shot bearing. A quick fix and $75 at the local parts depot and you're back on the road.
If it doesn't go away from this then it may be the front diff/transfer case and I don't touch those myself.
Kurtis
