Old 07-25-2009, 10:21 AM
jrush78 jrush78 is offline
Vehicle: 2000 Dodge Ram Quad Cab
Color: Blue
jrush78 is on a distinguished road
Default any head unit keeps turning off when I power on
Hello, this problem first started out that randomly the stereo would turn off then on, then it kept getting worse and worse. Now it stays off until I turn it back on but then it just goes right off. I thought it was the head unit so I changed it out with another one that I have in the garage, but that one does the same. I checked the battery connections and loosened everything and put it all back together secured. Also when it happens I can hear a clicking under the dash some where. I have searched online and this forum but found nothing so I thought I would post it here. Anyone have some suggestions? Oh I am using a wire harness to the OEM plugs so no spliced wires.
Old 07-25-2009, 10:41 AM
ljonesj ljonesj is offline
Vehicle: 2005 Dodge Ram Quad 1500
Rep:14
ljonesj is on a distinguished road
that plug adapter may hve went bad so check witha new one
Old 07-25-2009, 10:54 AM
There may be a relay (that's the clicking sound I think) that is going bad in the radio power circuit. Check the owner's manual electrical section, find the fuse and relay tables, then go under the hood and find the specific relay. Replace it. That may do it!
Old 07-15-2010, 03:05 AM
ramking ramking is offline
Vehicle: 2001 dodge ram
ramking is on a distinguished road
does the clicking happen when you turn the stereo on? if so thats the built in amp turnin on and off..i ran into the same problem with my after market stereo...it randomly decided to fix itself. wish i had an explanation as to how to fix it
Insane Wheeler
