Old 07-26-2009, 09:43 AM
RAMitDOWN's Avatar
RAMitDOWN RAMitDOWN is offline
Vehicle: 09 Dodge Ram
Trim Level: ST 4X4
Rep:24
RAMitDOWN is on a distinguished road
Default Wheel / Tire Upgrade
I see several threads about what larger size tire &/or wheel can fit but what I need to know is a little different then what I have seen posted.
My 09 (4X4) came with 17" wheels and 265/70/17 tires and what I am wanting to know is what size tire can I get with a 20" wheel and not have to add any lift or leveling kit ?
I am hoping to get a 20" wheel & tire that will give me the same diameter measurement as my current factory 17" set up I posted above.
Is this do-able ?
I plan on using the factory set up during the winter months.
Thanks for any help, RiD
Old 07-26-2009, 11:17 AM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:71
topgun will become famous soon enough
Your 17" rims and tires are smaller than the stock 20" rims and tires. The 17" you listed are showing to be about 31.6" tall, the stock 20" (which are P275/60R20) are about 33" tall. To get the same height tire with a 20" rim, you would need to get a P245/60R20. So no lift or level would be needed with either choice.
Go to Miata Net for a real good easy to use tire size calculator. You can plug the tire size in the box and compare with your stock tire. Brands will vary slightly but you can get an idea of what you may want to use.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Cooper AT3 285/70/R17's, S&B Intake, Moroso Catch Can
Old 07-26-2009, 02:23 PM
david55838's Avatar
david55838 david55838 is offline
Vehicle: 2009 1500 Quad Cab
Color: Borange
Rep:17
david55838 is on a distinguished road
Does anyone know if 20" wheels from a 2007 Ram would fit a 2009?
Thanks.
Old 07-26-2009, 06:07 PM
RAMitDOWN's Avatar
Trim Level: ST 4X4
Rep:24
Thanks thats what i needed.
Old 07-27-2009, 07:22 PM
kcr9220's Avatar
kcr9220 kcr9220 is offline
Vehicle: 09 Dodge Ram 4x4
Color: Inferno Red
Rep:16
kcr9220 is on a distinguished road
Send a message via Yahoo to kcr9220
Great site for tire sizing. Thanks
Old 07-28-2009, 01:28 PM
david55838's Avatar
Color: Borange
Rep:17
Thanks.
I'll answer my own question. Yes, they do - and they look great!
