Old 07-27-2009, 05:41 PM
ponchopower ponchopower is offline
ponchopower is on a distinguished road
Default AC issue
OK, first question as a member of the site - and yes, I did search first. I found 1 thread that's similar but not the same.
Just bought a 2004 QC 2500 6spd w/220k on it. Picked it up in FL and drove it to Pgh, PA on Saturday. Loved that Cummins on the hills. Not a bad truck, and doesn't seem mistreated.
Anyway, when started the AC comes on strong, cold and lots of velocity. The AC stays that way for at least 30-45min I'd guess. After a bit, however, the fan slows down and it seems not as "cold". Even set to recirc at the highest fan setting, no change. Engine temp stays normal. No noises, nothing. If I shut the truck off for even a minute or two, then restart it's back to full blast air. Shutting the air off and turning back on has no effect. Behavior did not change during the 820 mile trip back. Pretty much ran the truck for a solid 12 hours.
Anybody have any quick ideas? Thanks!
Old 07-27-2009, 06:31 PM
You could be low on refigerant causing the evaporator to freeze up . That would kill your air flow . Putting it on recirculate would only make it worse .
Old 07-27-2009, 06:59 PM
boostjunkie1's Avatar
boostjunkie1 boostjunkie1 is offline
Vehicle: 2008 Hemi Ram
Rep:62
boostjunkie1 will become famous soon enough
------- I had a 03 do the same thing ------ Check the refigerant........... These truck are also bad about having the Blend Door fail causing the AC to not work properly / not at all......
Old 07-28-2009, 12:54 PM
OK, so let me make sure I'm understanding. When started, air blows ice cold and at high volume for a while. After a while (30 min or more) fan slows WAY down. If I stop, and shut the truck down for 3 minutes for example, then restart it air is ice cold with fan at high speed again.
If low refrigerant caused evaporator to freeze, wouldn't it take a good bit more than a few minutes to thaw out?
Old 08-31-2009, 08:35 PM
inkboy inkboy is offline
inkboy is on a distinguished road
Dude I'm leaning to one of your cut out switches, (high pressure or low pressure) or the blend door. I'm going through the same problem with my 2000. Gonna pull off the dash and try to find the blend door this weekend.
