New owner of 01' Ram, got some??? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - News Desk > Newbie Checkin!
Newbie Checkin! New to the forums? Introduce yourself here!
Old 07-27-2009, 05:46 PM
Rhyno's Avatar
Rhyno Rhyno is offline
Vehicle: 2001 Dodge Ram 1500
Color: Tan and Silver
Rhyno is on a distinguished road
Default New owner of 01' Ram, got some???
I just bought an 01' Ram 1500 5.9 sport. I have a squeeling noise under hood (already replaced alt, checked water pump and greased some really bad tension pully's)any recommendations, should I get new pully's? Rear end likes to lock up when I first use brakes after a rain, mainly first or second brake then fine.
Old 07-27-2009, 06:18 PM
New to the Z for Rams myself . Welcome . Shouldn't have to replace pulleys . Maybe replace the belt . If it looks good , it could still be worn out . Depth of the belt could be shot . Rear brakes locking up could be out of round brake drums , misadjusted brake shoes ...
Old 07-27-2009, 06:41 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Welcome to RamForumZ!!! Might check the idle tensioner pulley too. Make sure it isn't wore out.
Old 07-27-2009, 07:26 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
Hello and welcome!
Glad to have you here, I hope you get your problem figured out!
Old 07-27-2009, 08:24 PM
OKCharger's Avatar
OKCharger OKCharger is offline
Rep:69
OKCharger will become famous soon enough
Welcome to the RAM Z from Oklahoma, hope you enjoy your stay!
2014 Mopar-Nation Midwest Meet
July 25-27 2014, Chickasha OK
Old 07-28-2009, 01:36 PM
LYC79's Avatar
LYC79 LYC79 is offline
Trim Level: SXT CRD 2.0 / 2.8
Rep:426
Welcome to the ForumZ !!! Glad you found us!
Old 07-28-2009, 03:48 PM
1970 Charger's Avatar
1970 Charger 1970 Charger is offline
Vehicle: 2009 Ram 1500 Crew Cab
Rep:28
1970 Charger is on a distinguished road
Welcome to the ZZZZZZZZZZZ from Illinois! Glad to have you as part of the Z family!
Old 07-28-2009, 07:32 PM
Rep:3347
Welcome to the Z! Sounds like Tom got the gist of what I was gonna say: the tensioner and belt probably need to be changed. Had a similar problem on an older dakota and the guys at my shop recommended changing both and problem solved.
Old 07-28-2009, 08:29 PM
Rep:4264
Welcome to the ForumZ and congrats on your truck. As far as the pulleys go, the bearings in them do eventually wear out, and it just depends on which one is bad as to whether you can get away with just replacing the pulley itself, like idler, power steering, crankshaft, or if you have to replace the whole part like the AC, where the pulley is pressed on. The best way to check is to use a stethoscope because with the truck running, the engine deflects the noise, which could lead you to the wrong one. Found out the hard way myself, so good luck.
Old 07-30-2009, 07:49 AM
300 Addict's Avatar
300 Addict 300 Addict is offline
Vehicle: Chrysler 300
Trim Level: Touring
Color: Satin Jade Metallic
Rep:317
300 Addict is a jewel in the rough300 Addict is a jewel in the rough300 Addict is a jewel in the rough300 Addict is a jewel in the rough
Welcome to the best Dodge Ram owners club forum on the net! Glad you joined our growing family of enthusiasts! Enjoy the site!
