Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10
Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 07-30-2009, 01:07 AM
ntubbert ntubbert is offline
Engine: 2003-2003 488ci (8.0L) Magnum V10 310hp 450lb/ft
ntubbert is on a distinguished road
Default V10 tune up after 118000 miles
my question or questions are i have a 99 v10 and the head gasket just went out. im fairly confident that i can do the fix my self but im also wondering if there are any suggestions in what i should change or fix while i have the engine torn apart. i also have a question regarding the cooling of the number seven piston i have heard cooling jackets were too small so the pistons would detonate and ruin the engine. ive done research about it but find almost nothing and wondered if anyone else thought it was a good possibility or if i should take extra precautions after i get the engine running.
Old 07-30-2009, 06:40 PM
Make sure you change your O2 sensors . The antifreeze contaminates the sensors . Alot of time cylinder head gasket manufacturers will hear of a constant problem and make a revision to a head gasket (larger or smaller passages) to try and correct a problem .
Old 01-07-2010, 08:02 PM
torp74's Avatar
torp74 torp74 is offline
Vehicle: 2002 Dodge Ram 2500 4X4 V10
torp74 is on a distinguished road
I think the detonation problem was with the '98 and earlier. At least that is what I read on another site.
Go Heavy!
head gasket, piston, tune up
