Old 08-01-2009, 11:31 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:71
topgun will become famous soon enough
That's what i would do. The oil in the pan should not be dirty. Maybe you can get away with a quart or two. Depends on how much blew out on the ground.
The Wal Marts around here have had Mobil 1 on sale for a couple of months at $22 for the 5 quart jugs.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Cooper AT3 285/70/R17's, S&B Intake, Moroso Catch Can
Old 08-02-2009, 12:07 AM
Glad you found your problem .
Old 08-02-2009, 01:27 AM
red041500 red041500 is offline
Vehicle: 2009 ram 1500 crew cab
Color: bright silver
Rep:22
red041500 is on a distinguished road
excellent , hopefully you'll find two gaskets up there. i would just check to make sure the gasket on the new filter is in good shape with no rips or tears , make sure the mount surface is clean , wheel the new filter back on and top it off. i ALWAYS double check the block , check the old filter make sure the old gaskets there and then scratch the mount surface with a finger nail. you got lucky , i've seen them not leak till you hit the highway and the oil pressure is sky high. by time you know what happened you already bought a motor.
Old 08-02-2009, 01:57 AM
You can try just removing the filter. I believe you are correct, you won't lose all the oil in the pan. I'd have the other filter ready, lube the new gasket, have the new filter close at hand and be ready to remove the old filter plus the double gaskets quickly.
Old 08-02-2009, 05:11 AM
Joe Rotax Joe Rotax is offline
Joe Rotax is on a distinguished road
After removing the old filter I look at it, check that the new one is the same, clean the block mounting surface with a rag and run my finger around it to feel for any grit or whatever that might be stuck there. And of course you have to put some oil on the new filter's rubber seal. Hand tighten and then about a 1/3 to 1/2 turn with a filter wrench depending how tight it feels.
Old 08-02-2009, 02:56 PM
david55838's Avatar
david55838 david55838 is offline
Vehicle: 2009 1500 Quad Cab
Color: Borange
Rep:17
david55838 is on a distinguished road
All's well that ends well! That was the problem. All better now, and thanks again everyone for your help. You saved me a big towing bill!
Old 08-03-2009, 04:03 AM
boostjunkie1's Avatar
boostjunkie1 boostjunkie1 is offline
Vehicle: 2008 Hemi Ram
Rep:62
boostjunkie1 will become famous soon enough
Buddy of mine just did that with a Cummins and some $$$$$ Royal Purple ....... A little oil on the ground looks like a couple gallons HUH???? Glad that was the issue and nothing major.
**So how much oil did you have to replace?
Old 08-03-2009, 11:09 AM
david55838's Avatar
Color: Borange
Rep:17
About 4 - 5 quarts and 20lbs. of kitty litter! Lesson learned I guess. When I pulled the filter off yesterday to look for the old gasket, there was nothing stuck to the block, so I thought, NOW WHAT? What I didn't see at first was that it had come loose and fallen on top of the cross member. Whew!
Old 08-03-2009, 08:52 PM
Rep:62
Your expereince is 99.999999% exactly like my buddies ...... Gasket was sitting on top of the front axle on his 2500....... Sounds like you lost almost 80% of your oil.......Whew, do not let the EPA get word of this!!
Old 08-03-2009, 10:18 PM
sinn's Avatar
sinn sinn is offline
Vehicle: 09 RAM CREW CAB
Color: RED
sinn is on a distinguished road
Originally Posted by david55838 View Post
Sorry, one more question. Can I just take the filter off and deal with the oil coming out of there, or do I need to drain the oil pan again with whatever's left over from my first try? I'm thinking since the filter isn't really near the pan, I can just do that. Save some $7 a quart oil too...
You probably blew all of the oil out of the pan when you first started it up, but NO you don't need to drain the pan. Just be careful that you don't overfill it!!!
Also, check the oil level again after you have run the engine and it has cooled down, as some of the oil level will go down as the filter and oil lines are filled.
