Old 08-02-2009, 11:38 PM
eastover4x4 eastover4x4 is offline
eastover4x4 is on a distinguished road
Default factory posi rear ends
im looking to buy a 1994-2001 ram 1500 4x4 how can i tell if its got a factory posi trac rear end or did they all come with them
Old 08-02-2009, 11:45 PM
Mine had a paper tag on the left tube that said limited slip . If it does make sure the diff has been serviced reguarly . The posi's in these from the factory required servicing every 15,000 miles . If they weren't and were neglected it would of practically destroyed the rear . I'm talking from experience . Dealer told me when I questioned them about this that they see it from time to time . Be careful .
Old 08-03-2009, 07:58 AM
Default limited slip
9 times out of ten a paper tag is gonna be gone anyother ways of telling on a used car lot? i know all the fords have a metal tag that tells you gears and if its open or limited slip ie a ford tag saying 3L73 is a 3.73 geared limited slip rear end. does dodge do something similar to help id the guts of the differential or what
Old 08-03-2009, 07:11 PM
ripper360x's Avatar
ripper360x ripper360x is offline
Vehicle: 2005 Dodge Ram Quad cab
Rep:14
ripper360x is on a distinguished road
if you could possibly test drive take it out and mash it to the floor and see what she does....
Old 08-04-2009, 04:23 PM
Default mashing it
good plan i might ask it its posi if the salesman dont know ill romp it up and look for the two black marks. i spend alot of time off asphalt for work and i aint playing with a one tire fryer. i want both my back tires to lock in and get me out. any ideas on good aftermarket limited slip or automatic lockers?
Old 03-11-2011, 10:38 PM
xnumnutsx xnumnutsx is offline
Vehicle: 1995 Dodge Ram 4x4
Trim Level: SLT laramine
Color: inferno red
xnumnutsx is on a distinguished road
i am also wondering the same thing so i can go find one in a junk yard to put in my truck.
Old 04-22-2013, 06:47 PM
White Ghost White Ghost is offline
Vehicle: 2001 Dodge ram off road
Trim Level: Laremie SLT
White Ghost is on a distinguished road
My 01 has a equipment id tag in glove box. If rear end is out of truck ,hold one axle and turn the other one. If it turns easy it is a one wheel peel. It should turn hard or not at all.If clutch pac is bad ,it will turn,but with some resitance. I hope this helps you.
