Easiest and best way to level my truck out? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-03-2009, 10:21 PM
ScatPackRam's Avatar
ScatPackRam ScatPackRam is offline
Vehicle: 2001 Dodge Ram 2500
Trim Level: base model
Engine: 1999-2001 359ci (5.9L) Cummins ISB 24-valve Diesel I6 230hp 450lb/ft (manual), 215hp 420lb/ft(auto)
Rep:17
ScatPackRam is on a distinguished road
Default Easiest and best way to level my truck out?
I want to level the ride from the front to the rear and get rid of the gap between the bed and the rear wheels. What is the easiest or th best way o lower the truck? Can I just lower the rear to ahieve my goal? I threw in a picture of the truck from the rear to show what I have.
File Type: jpg 3ka3oc3lfZZZZZZZZZ96u284e8bf382e21861.jpg (6.3 KB, 30 views)
2001 Cummins Dodge Ram 2500
2006 Dodge Charger SXT Inferno Red
Old 08-04-2009, 02:40 AM
boostjunkie1's Avatar
boostjunkie1 boostjunkie1 is offline
Vehicle: 2008 Hemi Ram
Rep:62
boostjunkie1 will become famous soon enough
2wd...get some lowering springs / leafs for the rear.. This will level it out from the rear..OR... Front will have to get spacers about 2".... One or the other
Old 08-04-2009, 06:46 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Shackles for the rear!
Old 08-04-2009, 10:55 AM
Rep:17
Explain what lowering springs/leafs and shackles are please?
Old 08-04-2009, 12:26 PM
chithead's Avatar
Rep:2078
The leaf packs are just replacement leaf springs for the rear axle. The shackles are what connects the leaf springs to the frame towards the rear of the truck. They allow the spring to move during flex so as not to bind up and rebound, causing a rough and bouncy ride. New leaf packs are always the safest option when changing suspension pieces. But shackles are usually the most cost effective when lowering the rear.
Old 08-04-2009, 05:41 PM
Most trucks the differential sits on the bottom of the leaf spring . Might try moving the differential to the top of the spring . Will have to weld another set of spring perches on the differential to do it though . I'm thinking of 4x4 . Not sure now if thats what you have on your truck .
Old 08-25-2009, 12:08 PM
aggie aggie is offline
Gender: Not Specified
Vehicle: 2006 Dodge Ram
aggie is on a distinguished road
Shackles if all you are wanting is a rear drop. CHEAP.
Old 10-18-2009, 12:08 PM
02quad ram 02quad ram is offline
Vehicle: 02 quad cab 2500 4x4 8ft box
02quad ram is on a distinguished road
after a little searching around,this thread seamed like a good one to bump for my question.
i have an 02 2500 ram 4x4 with a broken rear shackle.i'm not sure how common this is,but it's the only piece under the truck thats rusted.the bracket that mount's it to the frame isn't rusted.so,i'm not going to buy them from the dealer.i would like to find something from a reputable aftermarket brand.i've seen the belltech set,which might work with very little height difference.
now to the problem.
i can't seem to find a listing for my truck.they seem to list them for 94-01 1500's everywhere.i checked the link above at jeg's also(aggie posted).mine is still a 2nd gen body style,but not sure if the spring is wider then a 1500.i also found some listed up to 1999 for a 2500.
any opinion's and advise would be great from the more experianced.thanks in advance.
keith
Old 10-18-2009, 10:09 PM
Rep:3347
Quick question, is it a 3/4ton? if it's the 1/2 ton, the spring should be the same, but if it's a 3/4 ton you're looking at a beefier and thicker spring pack. I hope Greg jumps in too, he's done a lot more drops than I have. Also, if you're worried about them rusting again you could media blast the piece and get it powdercoated to protect it.
Also, stop by the Newbie section and get the official welcome!
