Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
View Poll Results: Synthetic after Dino in High mileage Engine
Yes ---- switching is fine 16 100.00%
No ----- your asking for trouble 0 0%
Voters: 16. You may not vote on this poll
Old 08-06-2009, 12:08 PM
GASHAWG's Avatar
GASHAWG GASHAWG is offline
Vehicle: 2000 Dodge Ram 1500
Color: Driftwood Satin
Rep:16
GASHAWG is on a distinguished road
Default Switching High Milage to Synthetic Y or N
I'm just got a 2000 4x4 1500 with the 5.9l and i was thinking of switching everything to amsoil. Oil, Oil filter, Lube, transmission fluid, gear oil ect.
But i keep hearing that if i switch to a synthetic i may be in for trouble with leaks around the seals,
The truck has no leaks around the engine it is spotless and it has 107K miles i'm worried i might mess up switching and causing leaks.
And for the record i'm not wanting to switch so i don't have to change my oil as often. I'm going to be pulling a 24' pontoon and i want the motor and tranny working as cool and comfortable as possible
2000 Dodge Ram 1500 single cab 4x4 Slt Laramie 5.9L
Old 08-16-2009, 09:14 PM
Magnum488's Avatar
Magnum488 Magnum488 is offline
Vehicle: 05 1500 4X4 Daytona
Trim Level: Daytona
Color: GoMango
Rep:13
Magnum488 is on a distinguished road
I switch back and forth from conventional to synthetic on my 95 318 RC 4X4 with 170k. I run synthetic in the winter here in MI. Summer I run either. No problems or leaks. It won't hurt anything.
12 Charger R/T R&T, Dynomax, Trinity, 180 stat
05 Daytona QC GoMango 4X4 Long tubes, Y-pipe, Airaid, NX 100 shot, Superchips
03 Durango's 4.7's 4X4's SLT one white one green
95 Ram 1500 4X4 MP computer, shift kit, more..
Old 08-16-2009, 09:47 PM
dodgenfrank's Avatar
dodgenfrank dodgenfrank is offline
Vehicle: '95 Dodge Ram 1500 4x4
Color: Scratchy Green
Rep:17
dodgenfrank is on a distinguished road
My 95 has 250k (+) and she loves the syn. Still purrs like a kitten.(when other issues don't let me down)
Old 08-16-2009, 11:07 PM
My Ram has 140,000 ,and I run Amsoil in it with no problems .
Old 08-17-2009, 09:29 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
I think most of the "high mileage" oils are either synthetic or a synthetic blend. I would say go for it, don't think it'll be a problem..
Exco
Bill
Old 09-15-2009, 06:56 PM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
yeah most high mileage oils are synthetic blend anyway, so that switching from full synthetic, back to high mileage sythetic blend will not be as bad as going from full synthetic to convensional...Although, valvoline claims that switching back and forth between oils, whether full synthetic or conventional, is not harmful to your engine. I dont see why you would want to do that, but I would not recommended it personally because of the different viscosity of the oils even though they are the same weight....ie, 5w20 full synthetic is a thicker viscosity than conventional 5w20...to me thats really not helping out the engine run properly because of the difference in the thickness of the oil when going back and forth...
Old 07-16-2010, 05:23 AM
LAN's Avatar
LAN LAN is offline
Vehicle: 2003 Dodge Ram 1500 V6
LAN is on a distinguished road
So how did this go?
I'm thinking about switching to synth-blend though and mine has half the mileage of yours.
Old 07-23-2010, 04:05 AM
LAN's Avatar
LAN LAN is offline
Well, I switched to SynthBlend from non-synthetic. Been running for a week now. No leaks yet. The oil got dirty though after a couple of days.
