View Poll Results: Synthetic after Dino Oil in High mileage Engine
Yes ---- switching is fine 27 77.14%
No ----- your asking for trouble 8 22.86%
Voters: 35. You may not vote on this poll
Old 08-06-2009, 12:59 PM
GASHAWG's Avatar
GASHAWG GASHAWG is offline
Vehicle: 2000 Dodge Ram 1500
Color: Driftwood Satin
Rep:16
GASHAWG is on a distinguished road
Default Switching to Synthetic in High Milage engine Y or N
I just got a 2000 4x4 1500 with the 5.9l and i was thinking of switching everything to amsoil. Oil, Oil filter, Lube, transmission fluid, gear oil ect.
But i keep hearing that if i switch to a synthetic i may be in for trouble with leaks around the seals,
The truck has no leaks around the engine it is spotless and it has 107K miles i'm worried i might mess up switching and causing leaks.
And for the record i'm not wanting to switch so i don't have to change my oil as often. I'm going to be pulling a 24' pontoon and i want the motor and tranny working as cool and comfortable as possible
Edit/Delete Message
2000 Dodge Ram 1500 single cab 4x4 Slt Laramie 5.9L
Old 08-06-2009, 04:03 PM
I have 140,000 miles on my truck and all I run is Amsoil . No leaks . The motor is as clean as the day it was new . You won't get the full benefit running it now . It's designed to reduce wear , and free up friction . Having 107,00 miles means the motor has gotten some wear on it . Changing over now won't hurt you , you'll still get excellent benefits from extended change intervals etc...
Old 08-06-2009, 05:17 PM
Red Ram's Avatar
Red Ram Red Ram is offline
Vehicle: 2008 Dodge Ram
Rep:21
Red Ram is on a distinguished road
I have an S10 that I bought with over 100K and it now has 218K and it never had synthetic in it until I put it in.... no leaks and it runs great
Old 08-07-2009, 10:12 AM
Morfias4twenty's Avatar
Morfias4twenty Morfias4twenty is offline
Vehicle: 2002 Dodge Ram 4x4
Rep:15
Morfias4twenty is on a distinguished road
Send a message via MSN to Morfias4twenty Send a message via Yahoo to Morfias4twenty
I have ran full synthetic in my truck since it had 20k in it.. truck has 71K i it now and no leaks ***( knock on wood) I ran Mobil 1 till about 60K the switched over to there 15,000 mile protection brand.. still mobil 1 though...(full synthetic still)
Old 08-08-2009, 08:25 PM
GASHAWG's Avatar
Rep:16
Still not sure about switching. The dodge Mechanic told me another story about leaking seals. He said if it ain't broke don't fix it. But i like to think preventative care would keep it from breaking.
Old 08-14-2009, 11:09 AM
GASHAWG's Avatar
Rep:16
Well i went ahead and changed it. Autozone had a sale on 5qt of mobile 1 and a mobile 1 oil filter for 26 bucks. I've gone about 300 miles since the oil change and i haven't seen any problems yet.
Old 09-07-2009, 03:49 AM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
Looks like you went ahead and did it. I was gonna suggest that you install the proper weight and also do a flush do there is no DINO oil residual left over to mix with the new Synthetic Oil.
Old 09-26-2009, 11:32 PM
Mcguinness's Avatar
Mcguinness Mcguinness is offline
Vehicle: 2009
Trim Level: ST Quad cab Hemi
Rep:28
Mcguinness is on a distinguished road
SLUDGE has been a problem for me in the past whe i tried synthetic and was told to treat once and then give it 3000 mile changes
Old 10-14-2009, 01:17 PM
RedneckDodge's Avatar
RedneckDodge RedneckDodge is offline
Vehicle: 1994 Dodge ram 1500
Trim Level: Magnum 4x4
Color: Red with silver and burgandy stripes
Rep:15
RedneckDodge is on a distinguished road
I switched my 94 dodge over 2 synthetic oil and it actually helped mine stop drinkin oil and mine hasn't run better. It won't hurt it but if u do switch don't switch back cause it will hurt u're engine then.
Old 09-13-2011, 02:51 PM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
Ok, I could give you a long answer with history etc. but I'll spare you and give you the short answer. Yes and No.
No - synthetic oil will not make you seals leak.
Yes - if you have seals which are going bad already and sludge from your old oil is helping plug potential leaks the synthetic oil may clear out that sludge and so a leak may appear but that is a bad seal and not the synthetic oil creating a leak.
No reason to do that Dino and synthetic are compatible. However, if you suspect there is a lot of sludge in your engine I would not go more than 3000 miles before the next oil change. Save extended change intervals for a clean engine.
