Old 08-06-2009, 07:49 PM
06DodgeRam 06DodgeRam is offline
06DodgeRam is on a distinguished road
Default Cold Air intake question
i have a k&n cold air intake, i got a hemi does anyone else have the air intake on and does it make a weird tickin noise at lower RPM's..i checked and checked can't be a air leak everything's tight and sealed..
2013 Ram: Tinted windows
Old 08-06-2009, 08:11 PM
ramit04's Avatar
ramit04 ramit04 is offline
Vehicle: 2004 Dodge ram 1500
Rep:74
ramit04 will become famous soon enough
vacume line?
Old 08-06-2009, 10:12 PM
johnnyk416's Avatar
johnnyk416 johnnyk416 is offline
johnnyk416 is on a distinguished road
Send a message via MSN to johnnyk416
Hemi tick ......... its the EGR valve gets intensified by cold air intakes, nothing to worry about
Old 08-06-2009, 10:14 PM
Never heard of it . Good to know .
Old 08-06-2009, 10:19 PM
johnnyk416's Avatar
LOL ..... thats because you don't have a Hemi. Search other forums Like HTC you will find many posts on it. Almost sounds like valves out of adjustment or an exhaust leak..... very noticeable at a drive up teller window(kinda embarrassing to)........LOL
Old 08-07-2009, 08:44 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
I had a K&N Typhoon on my wife's Magnum. I had what often sounded like a "pinging" sound coming from under the hood. It was mostly during acceleration, but it also happened sometimes at idle.
Came to the conclusion that it was the warmer air from the engine bay, mixing with the cooler air that it was sucking in, (it seems that the seals around the heat shield were not very good, if they worked at all).
I had a friend of mine help me to better close up the open spaces around the heat shield. We used a bit of sheet metal, some quick welds, and a bit of weather stripping. The decreased the pinging, but didn't completely cure it.
Not sure if you've got the same problem, but that's what happened with me. I've had no trouble out of the AEM brute force I've got on my Ram...
good luck
Exco
Bill
Old 08-07-2009, 04:29 PM
No but being a mechanic and working on them
Old 08-07-2009, 11:24 PM
oookay, so could be the EGR or could be the warm cool air mixing, and yes all vaccum lines are sealed...i tried everything from grabbin the shield box and shakin the heck out of it to pullin the heat shield off the inside of the hood cuz i thought maybe it suckin air it was vibrating it cuz there not put up there very tightly....but u guys think this is nuttin to worry about, cuz i know that somethings with air intakes not on right can lead to serious problems...thanks for all the input also
Old 08-07-2009, 11:26 PM
AND YES IT'S THE ANNOYING SOUND OF A EXHAUST LEAK....but mine only makes the noise on easy acceleration at low RPM, when im into it, no noise
Old 08-08-2009, 12:27 AM
TerryXn9's Avatar
TerryXn9 TerryXn9 is offline
Vehicle: 2010 RAM
Trim Level: Crew Cab Sport
Rep:31
TerryXn9 is on a distinguished road
I got the 4.7 magnum with no cai. It makes a ticking noise at idle. I took it to the dealership and they told me it was the hydralic lifters. They also said its louder in the hemi. Not sure if thats what it is but it took my mind off of my problem.
2010 Crew Cab Sport! With a HEMI
