Old 08-06-2009, 10:14 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Default Nerf bar question
I am in need of some pics of how nerf bars attach to my truck. I have an 01 1500. thanks.
Old 08-07-2009, 07:55 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
They're pretty straight forward on how they install. The brackets will only go on one way. The only issues that I ran into was the lock washers were a bit tight on a couple of the bolts.
I'll try to go out and crawl under the truck and get a couple of pics (after I wake up a little), but they're not tough to install....
Exco
Bill
Old 08-07-2009, 12:22 PM
Rep:1930
Exco
I am actually modifying a set that came off a H2 Hummer. So just needing spot where they normally mount, to see how close I can get them.
Old 08-07-2009, 03:10 PM
I'd buy the ones for the truck . Quad cab truck nerf bars have the step for the rear door . Make sure the ones you get are stainless steel . I got the regular steel ones and got three years out of them until one day I was picking my ass up off the ground .
Old 08-11-2009, 05:21 AM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Ordered mine from TruckChamp.com, under $200 for everything. Stainless steel, put on in under 2 hours. They say no drilling required, but you do need to drill 2 holes for the support bracket. Instructions were clear, except for where to drill for the brackets. Once I had that on the driver side, passerger side went on in about 40 min.
