Old 08-11-2009, 12:06 PM
paxmaster2000 paxmaster2000 is offline
Vehicle: 00 ram sport, 12 journey
Trim Level: sport, avp
Color: green met, pearl blue
paxmaster2000 is on a distinguished road
Default wire for the reverse lights o8 ram
i need the wire color for the reverse light on my 08 ram. i bought a light bar from recon.
thank you
Old 08-12-2009, 09:43 AM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
I forget the actual color, but it's not hard to find. If you don't already have one, head down to Sears, Radio Shack, or even a hardware store and get a cheap electrical meter that will read DC voltage. they can be found for under $20
Once this is done, remove your taillight assembly (only a couple of screws) and unplug the connector, and without starting the truck ( and with the e-brake set) place the gear lever in reverse, this will light up your reverse lights.
Place the black (negative) lead solidly against the frame of the truck or other unpainted surface. There should be only one wire that has voltage on it when set up like I described above. simply put the red (hot) lead against each terminal in the connector until you find the right one, you should get about 12V DC
good luck
Exco
Bill
