Old 07-22-2009, 07:55 PM
Ram-RN's Avatar
Ram-RN Ram-RN is offline
Vehicle: 2002 Dodge Ram Quad 5.9
Ram-RN is on a distinguished road
Default Front Brake Discs
Hello,
Would a warped disc cause vibration from the steering wheel? Seem that when I accelerate from 35mph to 45 mph my steering wheel vibrates. I looked at my pads and they seem to have plenty of meat left. But after driving around using the brakes for a few miles I hear a squeak from the front discs. Thanks in advance.
Old 07-22-2009, 10:12 PM
It could . Could also be about anything from a worn steering component to a sloppy u-joint .
Old 07-22-2009, 10:40 PM
DodgeRR DodgeRR is offline
Vehicle: 2005 Dodge Ram 1500 Hemi
Trim Level: SLT 4x4
Rep:13
DodgeRR is on a distinguished road
could also be front wheel alignment or rotors could be warped
Old 07-22-2009, 11:05 PM
jxoh jxoh is offline
Vehicle: 2005 Ram 1500
Color: Grey
jxoh is on a distinguished road
If it vibrates at higher speeds, you might want to get the front wheels balanced.
i would do the alignment and balancing before looking into the other things unless you know for sure it's not the wheels or alignment.
Old 07-24-2009, 08:47 AM
gmag69's Avatar
gmag69 gmag69 is offline
Vehicle: 2007 Dodge ram quad cab
Trim Level: Big Horn edition
Rep:18
gmag69 is on a distinguished road
You could also have broken belts in one of your front tires. It is most likely an out of balance tire though. Check your rims for built up dirt and gunk on the inside of the rim also. if there is any clean it out. You'd be suprised how just alittle bit of dirt can throw your wheel out of wack.
