Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 08-18-2009, 03:54 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
Default How to: Clean Your Cold Air Intake
Ok, It has came to my attention that the instructions on the K&N recharge kit are really vague, and yes I have to agree they are. SO...
For all of you that have had problems with the directions here is detailed instructions via your best friend Alex . This is for all of you cold air intake owners. OH by the way, there is an aerosol can involved, so for all of you enviromentalists, sorry. A. Do not recharge your filter. B. Buy a prius. C. Do not pass go and do not collect your $200. Anyways...
You will need...
1. a towel
2. flat head screw driver
3. k&n recharge kit
4. A few hours spare time
5. Vaccum or Shop Vac
Step 1. Open your hood and find the cold air intake assembly.
Step 2. Remove the filter using a flat head screwdriver
Step 3. Set up your work station. I just used a towel as a place mat, (strongly reccomended, the oil may stain)
Step 4. Carefully take your filter and knock off any big particles of debris.
Step 5. Open the K&N recharge kit, and grab the "Air filter cleaner."
Step 6. Apply the Air filter cleaner onto your filter very very generously. Do not be afraid to really lather it on there. And DO NOT spray the inside of your cold air intake filter.
Step 7. Let sit for about 10-15 minutes.
Step 8. Once settled, Hose it off from only the outside, yes it will bleed through to the inside, don't worry about that.
*NOTE* It may be neccessary to repeat steps 6-8 depending on how dirty your filter is, I had to repeat a few times.
Step 9. Let dry. It should be white (ish). Now I know you guys are anxious to get this back on and oiled, etc. The drying process took about an hour. The water likes to pool up on the bottom of the filter, gently spin the filter and knock this excess off, it will speed up the process.
Step 10. Once the filter has dried, remove the "Air Filter Oil." (depending on the kit you get there may be a squeeze bottle and aerosol bottle. I personally have used both. i'll have steps A. for aerosol bottle and B. for squeeze bottle)
Step 11A. Using the aerosol bottle, Apply evenly accross the filter so that it should look red. DO NOT APPLY INSIDE THE FILTER. I applied it about 5 pleats at a time. 2 squirts, 1 up, 1 down. Then move on.
Step 11B. Using the squeeze bottle, Apply 1 drop to the top of each pleat and let sit. DO NOT APPLY INSIDE THE FILTER.
Step 12A. Let dry for 20 minutes.
Step 12B. Next, apply a line of oil to each pleat, Just enough to cover the edge of each pleat. I promise, the oil will soak into every crevice
Step 13A. You may have spots that are lighter than others or may not. If you do, touch these up with more oil.
Step 13B. Let dry for 20 minutes.
**AT THIS POINT** The filter may or may not be dry, and I know your wondering, "well maybe I over oiled, I don't want to hydrolock" or whatever other excuses you can think of.
Don't worry, THERE IS A SOLUTION! To simulate the sucking of an engine, grab a vaccum or shop vac of some sort. Suck any excess beads off, (most of the oil has settled by now... I promise). Once the exterior is looking bead free, go ahead and suck from the inside for a while, This will pull the excess in, and then out.
Step 14 (all). Re-install the filter back on to your car.
Step 15 (all). Turn on the car, let idle for 10 minutes or so just to make sure there is no leaks, and so that your car can get used to breathing again
Step 16 (all). Drive around for a few miles, and check up on how tight the clamp is and that there is still no leaks.
Step 17 (all). Party it up, because you have successfully cleaned and RECHARGED your K&N filter without damaging anything! Congratulations!
Old 08-18-2009, 04:02 PM
300 Addict's Avatar
300 Addict 300 Addict is offline
Vehicle: Chrysler 300
Trim Level: Touring
Color: Satin Jade Metallic
Rep:317
300 Addict is a jewel in the rough300 Addict is a jewel in the rough300 Addict is a jewel in the rough300 Addict is a jewel in the rough
Great writeup! A nice addition to our Knowledge Base Section! Thank you for sharing with us!
Old 08-18-2009, 04:04 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Great instructions!
Sounds good to me . Will try to give you some rep for that .
Old 08-18-2009, 04:05 PM
98sst's Avatar
Trim Level: SS/T
Rep:883
By the way, If your still questioning this process, Contact K&N through their website, email at Tech@knfilters.com, or even call tech/customer service at 1-800 858 3333. I assure you, you'll do just fine :P
Old 04-29-2010, 10:42 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
cool
Old 04-30-2010, 01:42 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Nice job with the write up. I didn't want to go with K&N because of the cleaning procedure. I am now using an Amsoil filter that only requires blowing out, or vacuuming every few thousand miles. Might have gone with the K&N had the instructions been clearer. Thanks.
Old 05-27-2010, 02:54 PM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:432
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
Great writeup! I too like that the Mopar filter doesn't require any oiling. You just wash it in warm soap and water and let it air dry.
Old 05-27-2010, 03:04 PM
Rep:1909
You mean I can't wash my K&N out with the pressure washer here at work and then oil it with M1 5W-30?
Old 05-27-2010, 07:35 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
You said not to rinse from the inside???? the K&N kit that i have clearly says to let the water run from the inside out, to push loose all the particles that were stuck in it? so when you said hose from the outside it got me wondering..some clarification on that would be nice!
Other then that its a great write up
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
air, cold, diy, howto, intake
