Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 08-18-2009, 08:09 PM
dicky dicky is offline
dicky is on a distinguished road
Default FAN options
i have a 06 mega cab wth the towing package,i'm hearing that a electrical fan is better than a crank fan.
really what is the difference, especially if the truck already has the rads for the towing portion.
anyone ?
Old 08-18-2009, 08:38 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
A little extra cooling never hurt... I wouldn't take away what CFM you have stock though. Maybe a push/pull electric fan? Replace the stock pulley mounted fan with two electrics pulling and add one in the front pushing?
Old 08-18-2009, 09:17 PM
pwrwgnman's Avatar
pwrwgnman pwrwgnman is offline
Vehicle: 4 trucks
Rep:17
pwrwgnman is on a distinguished road
it takes hp to turn a fan on the front of an engine, if ya change over and get an electric setup going it helps hp and mpg, not sure how much but anything and everything ya do will add up,
like chithead said watch cfms for the fan, make sure its gonna move as much or more than the stock setup...
Old 08-18-2009, 10:31 PM
May want to check out Flex-A -Lite . Have an excellent selection .
Old 08-18-2009, 11:08 PM
Flex A Lite makes some good stuff. Their kits fit. If you are a do it yourselfer, check out the junk yards for a wrecked Charger, Magnum or 300..they have electric fans.
Old 08-18-2009, 11:23 PM
pwrwgnman's Avatar
Vehicle: 4 trucks
Rep:17
what operates the fan? Does it have a thermal switch in the block? it would be cool to get an electric water pump too I havent seen many of those around lol
Old 08-19-2009, 07:06 AM
chithead's Avatar
Rep:2078
The electric fans will have a probe that comes with them. You are supposed to wedge it between the fins of your radiator and then use the set screw to determine what temperature it activates. I just used a toggle switch, when the temp gauge moved up, flipped it on!
Old 08-19-2009, 01:10 PM
pwrwgnman's Avatar
Vehicle: 4 trucks
Rep:17
a toggle switch would mean I gotta pay attention lol,
Old 08-19-2009, 02:22 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
...I've run a Mark VIII fan and am now using a Taurus fan...I do tow a boat (last time in 90+ degree weather, 2 hour drive one way, ac on the whole time) and it still kept it below the 12 o'clock line...
Old 08-26-2009, 10:51 PM
wildboyzracing wildboyzracing is offline
Vehicle: 99 dodge ram
Color: red/silver
wildboyzracing is on a distinguished road
you can buy a wiring kit with a temp sensor that will wire up any fan to any truck. try googling aftermarket fan wiring or look at jegs or flexalite
