Old 08-19-2009, 04:53 PM
808ram 808ram is offline
Engine: 1999-2001 359ci (5.9L) Cummins ISB 24-valve Diesel I6 230hp 450lb/ft (manual), 215hp 420lb/ft(auto)
808ram is on a distinguished road
Default Overhead display says CCD
My overhead display shows CCD intermittantly. What does this mean? how do I check it? and what might I need to do to repair it?
2001 dodge ram 3500 CTD 5.9 6cyl.
Thanks
Old 08-25-2009, 12:37 AM
toeknee22 toeknee22 is offline
Vehicle: 01 Dodge Ram 3500 V10
toeknee22 is on a distinguished road
i cant remember what ccd stands for but in basic term its called a ccd bus, basically the oh console module is not communicating with body control module so you want to check power and ground pins or you just might have a bad module, sorry.
Old 08-25-2009, 12:41 AM
sorry, being that its interminent i would also look for a rubbed through wire somewhere. if you can follow back the harness from the oh console and slowly twist it to see if the display flickers then you might have an idea where its at and you can open up the harness
