Old 08-22-2009, 11:32 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3944
Default 2009 TSBs
As we find the TSBs for the '09s let's post them here. I copied the one I knew of to start this off. Please keep this for '09 Rams only (or unless it applies to all Rams then I can sticky that in the appropriate area).
2009 Dodge Truck RAM 1500 2WD V8-5.7L
Vehicle Level Technical Service Bulletins All Technical Service Bulletins Wheels/Tires - Vehicle Vibration/Shake At Highway Speed Wheels/Tires - Vehicle Vibration/Shake At Highway SpeedNotesNUMBER: 22-001-09
GROUP: Wheels/Tires
DATE: Pending Approval
SUBJECT:
Vehicle Vibration Or Shake At Highway Speed
OVERVIEW:
This bulletin provides information to diagnose vehicle vibration concerns at or during PDI or if the vehicle is stored for a length of time prior to delivery.
MODELS:
2009 (DS) Ram Truck (1500)
DISCUSSION:
Tires used on the 1500 Ram models can develop a temporary flat spot when sitting on the lots and or while being shipped. This condition is more prevalent on 4 x 4 Models with 20" tires and wheels due the additional weight on the front tires from the unique components (i.e., front axle and transfer case). Weather is a critical factor and temperatures significantly above and below normal temperatures can temporarily "flat spot tires when vehicles are shipped by car hauler or rail or if vehicles are stored for an extended period. The vibration may be felt in the steering wheel and I or seat, and may be most noticeable at highway speeds, 60mph (96 kph). This may be misinterpreted as an out of balance tire.
DIAGNOSIS:
If the tires are flat-spotted due to shipping or sitting in the lot for an extended period, the vehicle vibration will go away after the tires are warmed up, (normally 10 to 20 miles of highway driving depending on outside temperatures).
REPAIR PROCEDURE:
1.Road test vehicle 10-20 miles to allow the tires to obtain operating temperature.
2.If highway driving doesn't resolve the vehicle vibration, follow the procedures outlined on DealerCONNECT>TechCONNECT > Group 22 - Tires and Wheels.
NOTE :Replacing tires should only be done as a last resort after all appropriate wheel and tire diagnostics have been completed. U.S. dealers can contact the MOPAR tire program if assistance is needed with obtaining any tire. Canadian dealers can contact the MOPAR tire program if assistance is needed with obtaining any tire.
POLICY:
Reimbursable within the provisions of the warranty.
Old 08-23-2009, 10:19 PM
Rogue's Avatar
Rogue Rogue is offline
Vehicle: 2009 Ram 1500 Crew Cab 4x4
Trim Level: TRX, 25T pkg w 5.7 L
Rep:22
Rogue is on a distinguished road
Send a message via ICQ to Rogue
Default These arent TSB but are registered complaints
These are not Technical Service Bulletins but they are complaints that are being registered with the company and may turn in to TSB's.
CONSUMER COMPLAINT: ODI Case Number: 10261557
Component: SEATS
Details: THE HEATED AND VENTILATED OPTION SEATS IN THE 2009 DODGE RAM FAIL PREMATURELY. I HAVE A 2009 DODGE RAM CREW CAB LARMIE WITH 1400 MILES. SEAT COVER REPLACED AT 800 MILES BY DODGE. SEAT COVER REPLACING AGAIN AT 1400 MILES. I ALSO HAVE A 2009 DODGE RAM QUAD CAB, SAME HEATED VENTILATED SEATS. IT NEEDS TO BE REPLACED NOW WITH 415 MILES TOTAL MILES ON THE TRUCK. CHRYSLER HAS A REAL PROBLEM WITH THE HEATED VENTILATED LEATHER TRIMMED SEAT COVERS AND THEY WILL NOT ACKNOWLEDGE MY COMPLAINT. *TR
Occurrences: 1 Injuries: 0
Fail Date: 02/03/2009 Deaths: 0
Date added to datbase: 3/11/2009
[FILE] your own complaint on this model car.
Yes, include on Custom Report CONSUMER COMPLAINT: ODI Case Number: 10257723
Component: SEATS
Details: 2009 DODGE RAM WITH VENTILATED SEATS. PERFORATED MATERIAL BETWEEN THE LEATHER TRIM WITH HOLES IN IT FOR AIR TO PASS SHOWS EXCESSIVE WEAR AFTER 1236 MILES. THIS AFFECTS 7 2009 DODGE RAM LARAMIE TRUCKS THAT I AM AWARE OF AS OF 2.6.2009. *TR
Fail Date: 01/10/2009 Deaths: 0
Date added to datbase: 2/6/2009
CONSUMER COMPLAINT: ODI Case Number: 10257734
Component: UNKNOWN OR OTHER
Details: EXCESSIVE WIND NOISE ABOVE 60 MPH. WORSENS AS SPEED INCREASES. OBVIOUS AT 30MPH BUT UNBEARABLE BY 60MPH. ABSURD BY 70MPH. *TR
Fail Date: 01/03/2009 Deaths: 0
CONSUMER COMPLAINT: ODI Case Number: 10265727
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Details: AT ABOUT 1200 MILES ON VEHICLE NOTICED A LOW SQUEAL SOUND FROM ENGINE OR TRANSMISSION. AT PRESENT THERE IS 1500 MILES ON VEHICLE AND THE SQUEAL HAS GOTTEN WORST. THE NOISE BEGINS AFTER ABOUT ONE OR TWO MINUTES OF STARTING, AND IS CONTUMELY SQUEALING. THE DEALER SHIP RAN TEST AND SAID IT WAS NORMAL. I DROVE ANOTHER 2009 1500 RAM AND THE NOISE WAS NOT THERE, OR IN THE NEXT 1500 RAM FROM ANOTHER DEALERSHIP. DEALERSHIP REFUSES TO GO ANY FURTHER WITH THE PROBLEM, QUOTE: WE CAN¿T FIGURE WHERE THE NOISE IS COMING FROM, SO IT MUST BE NORMAL UNQUOTE. VEHICLE IS SWB. *TR
Fail Date: 04/11/2009 Deaths: 0
Date added to datbase: 4/17/2009
The website that I used is
http://www.mycarstats.com/safetystat...?cars=12802557
I posted these to help anyone with similar issues, to let them know that they can register complaints and may get them raised to a TSB.
I have not had any issues other than the remote start feature.
Old 08-23-2009, 10:29 PM
Rogue's Avatar
Rep:22
Default These are TSB's
These are the TSB's that Edmunds.com has listed
2009 Dodge Ram Pickup 1500 Laramie 4dr Crew Cab SB (5.7L 8cyl 5A)
Component Description:
1. ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL Bulletin Number: J-04
Bulletin Date: Mar 2009
Vehicle: 2,009 Dodge Ram Pickup 1500
Summary:
DODGE: A NON APPLICABLE VEHICLE EMISSION CONTROL INFORMATION (VECI) LABEL WAS INADVERTENTLY INSTALLED. CSC LETTER WAS RECEIVED. ( NHTSA ITEM NUMBER - 10028833 )
2. EQUIPMENT:OTHER:LABELS Bulletin Number: J-04
Summary:
3. TIRES Bulletin Number: SB-22-0001-0
Summary:
CHRYSLER: VEHICLE VIBRATION OR SHAKE AT HIGHWAY SPEED: THE TIRES ARE FLAT SPOTTED DUE TO SHIPPING OR SITTING IN THE LOT FOR AN EXTENDED PERIOD, THE VEHICLE VIBRATION WILL GO AWAY AFTER THE TIRES ARE WARMED UP, (NORMALLY 10 TO 20 MILES OF HI ( NHTSA ITEM NUMBER
Website:
http://www.edmunds.com/maintenance/r...b&serviceType=
Vehicle: Blue
Rep:3944
Great input!
Old 08-27-2009, 11:19 PM
Rogue's Avatar
Rep:22
Default These are Recalls as listed by Edmunds.Com
Nature of Defect:
1. EQUIPMENT:ELECTRICAL:AIR CONDITIONER Recall Number: 09V158000
Dates Manufactured: Apr 2008 to Jan 2009
Number of Vehicles Affected: 37407
Date Owners Notified On: N/A
Vehicle: 2009 Dodge Ram Pickup 1500
Defect Description:
CHRYSLER IS RECALLING 37,407 MY 2009 DODGE RAM LIGHT DUTY PICKUP TRUCKS EQUIPPED WITH MANUAL TEMPERATURE CONTROL (MTC) ONLY. THE SOFTWARE PROGRAMMED INTO THE HEATING VENTILATION AND AIR CONDITIONING MODULE MAY CAUSE THE WINDSHIELD DEFROSTING AND DEFOGGING FUNCTIONS TO BECOME INOPERATIVE.
Consequence of Defect:
THIS CAN DECREASE THE DRIVER'S VISIBILITY UNDER CERTAIN DRIVING CONDITIONS AND RESULT IN A CRASH WITHOUT WARNING.
Corrective Action:
DEALERS WILL REPROGRAM THE HVAC MODULE FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING JUNE 2009. OWNERS MAY CONTACT CHRYSLER AT 1-800-835-1403.
Nature of Defect:
2. VISIBILITY:WINDSHIELD WIPER/WASHER:MOTOR Recall Number: 09V084000
Dates Manufactured: Apr 2008 to Oct 2008
Number of Vehicles Affected: 72136
Defect Description:
CHRYSLER IS RECALLING 72,136 MY 2008-2009 LIGHT AND HEAVY DUTY RAM PICKUP TRUCKS. THE WINDSHIELD WIPER MODULE MOTOR ASSEMBLY MAY BE SUSCEPTIBLE TO WATER INTRUSION THAT COULD RESULT IN PARTIAL OR COMPLETE LOSS OF WINDSHIELD WIPING CAPABILITY.
WHEN THE WIPER SYSTEM FAILS, THE OPERATOR WILL HAVE REDUCED VISIBILITY WHICH COULD RESULT IN A CRASH.
Corrective Action:
DEALERS WILL REPLACE THE WIPER MODULE ASSEMBLIES WITH VENTED WIPER MOTOR HOUSINGS FREE OF CHARGE. THE MANUFACTURER HAS NOT YET PROVIDED AN OWNER NOTIFICATION SCHEDULE. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403.
Nature of Defect:
3. POWER TRAIN:CLUTCH ASSEMBLY:PEDAL/LINKAGE Recall Number: 09V078000
Dates Manufactured: Aug 2008 to Jan 2009
Number of Vehicles Affected: 507
Defect Description:
CHRYSLER IS RECALLING 507 MY 2009 DODGE RAM 2500/3500 PICKUP TRUCKS HEAVY DUTY CAB CHASSIS WITH MANUAL TRANSMISSION AND POWER ADJUSTABLE PEDAL PACKAGE. THE CLUTCH PEDAL CONNECTING ROD TO THE CLUTCH MASTER CYLINDER MAY SEPARATE FROM THE MASTER CYLINDER. THIS MAY NOT ALLOW DISENGAGEMENT OF THE CLUTCH WHEN THE PEDAL IS DEPRESSED, WHICH COULD RESULT IN UNINTENDED VEHICLE MOVEMENT.
INCREASED STOPPING DISTANCE AND ENGINE STALLING MAY OCCUR INCREASING THE RISK OF A CRASH.
Corrective Action:
DEALERS WILL REPLACE THE CLUTCH MASTER CYLINDER HYDRAULIC SYSTEM FREE OF CHARGE. THE MANUFACTURER HAS NOT YET PROVIDED AN OWNER NOTIFICATION SCHEDULE. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403.
Nature of Defect:
4. VISIBILITY:WINDSHIELD WIPER/WASHER Recall Number: 09E009000
Dates Manufactured: N/A to N/A
Number of Vehicles Affected: 1364
Defect Description:
CHRYSLER IS RECALLING 1,364 WINDSHIELD WIPER MODULES, P/N 55077098AJ, SOLD DURING THE 2008 AND 2009 CALENDAR YEAR FOR USE AS AFTERMARKET REPLACEMENT EQUIPMENT ON MY 2002-2009 DODGE RAM PICKUP TRUCKS. THESE WIPER MODULE ASSEMBLIES MAY BE SUSCEPTIBLE TO WATER INTRUSION THAT COULD RESULT IN PARTIAL OR COMPLETE LOSS OF WINDSHIELD WIPER CAPABILITY.
Corrective Action:
DEALERS WILL REPLACE THE WIPER MODULE ASSEMBLIES WITH VENTED WIPER MOTOR HOUSINGS FREE OF CHARGE. THE MANUFACTURER HAS NOT YET PROVIDED AN OWNER NOTIFICATION SCHEDULE. OWNER MAY CONTACT CHRYSLER AT 1-800-853-1403.
Old 09-18-2009, 07:19 PM
chuck4411 chuck4411 is offline
Vehicle: 2009 ram crew cab 4x4
Trim Level: laramie
chuck4411 is on a distinguished road
Default same problem
rougue: how do i file a complaint. i have the squeaking sound that u describe in ure list of complaints, they told me it wasn't a tsb and all hemi trucks sound like that. thnx
Component: SEATS
Component: SEATS
Old 09-18-2009, 09:52 PM
Rogue's Avatar
Rep:22
Default How and where to file a complaint
Filing an Official Consumer Complaint about Your Car
Why File Your Complaint
The U.S. Department of Transportation encourages consumers to file an official complaint of record with them when the suspect safety issues with their model car. This information will be entered into National Highway Traffic Safety Administration's (NHTSA) vehicle owner's complaint database and used with other complaints to determine if a safety-related defect trend exists.
Your complaint is important in determining if further action is needed to investigate the possibility of a recall.
How Your Complaint is Handled
If a safety-related defect is determined to exist by NHTSA in a motor vehicle or item of motor vehicle equipment, the manufacturer must fix it at no cost to the owner. Your complaint is the first step in the process.
Government engineers analyze the problem. If warranted, the manufacturer is asked to conduct a recall. If the manufacturer does not initiate a recall, the government can order the manufacturer to initiate a recall.
There is not a specific number of complaints which need to be filed before a problem is investigated.
Steps to File Your Complaint
There are two ways you can file an official complaint about a model car with NHTSA.
FILE ON-LINE: You can file your official complaint directly on-line by clicking here.
http://www-odi.nhtsa.dot.gov/ivoq/
FILE BY PHONE: Call the DOT Vehicle Safety Hotline at 1-888-DASH-2-DOT (1-888-327-4236) while a NHTSA representative will record your complaint and other pertinent information.
The Privacy Act of 1974 - Public Law 93-579
As Amended: The information that will be requested pursuant to the authority vested in the National Highway Traffic Safety Act and subsequent amendments. You are under no obligation to respond to this questionnaire. Your response maybe used to assist the NHTSA in determining whether a manufacturer should take appropriate action to correct a safety defect. If NHTSA proceeds with administration enforcement or litigation against a manufacturer, your response, or statistical summary thereof, may be used in support of the agency's action.
Old 10-22-2009, 10:24 PM
Rogue's Avatar
Rep:22
Default One more TSB out there
4.TIRES
1. STRUCTURE:BODY:TAILGATE Bulletin Number: SB-09-035
Bulletin Date: May 2009
Summary:
CHRYSLER/DODGE: TAILGATE SPOILER MODIFICATION. VEHICLES MAY REQUIRE THE ADDITION OF TWO SIDED TAPE TO THE INBOARD EDGE OF THE TAILGATE SPOILER TO PREVENT THE SPOILER FROM TEARING OFF THE TAILGATE WHEN CARGO IS UNLOADED. ( NHTSA ITEM NUMBER - 10030346 )
2. ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL Bulletin Number: J-04
Summary:
3. EQUIPMENT:OTHER:LABELS Bulletin Number: J-04
Summary:
4. TIRES Bulletin Number: SB-22-0001-0
Summary:
CHRYSLER: VEHICLE VIBRATION OR SHAKE AT HIGHWAY SPEED: THE TIRES ARE FLAT SPOTTED DUE TO SHIPPING OR SITTING IN THE LOT FOR AN EXTENDED PERIOD, THE VEHICLE VIBRATION WILL GO AWAY AFTER THE TIRES ARE WARMED UP, (NORMALLY 10 TO 20 MILES OF HI ( NHTSA ITEM NUMBER - 10028944 )
Old 10-22-2009, 10:42 PM
Rogue's Avatar
Rep:22
Default Different site--different info
Automotive Recall and Technical Service Bulletin Titles for 2009 Dodge Truck RAM 1500 4WD V8-5.7L.
TSB Number & Issue Date TSB Title
H46 APR 09 Recall - Steering Linkage Defect
H36 FEB 09 Recall - Steering Drag Link/Steering Damper Bracket
J04 MAR 09 Recall - Incorrect VECI Label Installed At Production
23-012-09 MAY 09 Body - Hood Creaking And Squeaking Sound
23-011-09 APR 09 Interior - Front Seat Clicking/Squeaking/Creaking Noises
08-008-09 APR 09 Wipers/Washers - Washer Solvent Level Sensor Weepage
22-001-09 MAR 09 Wheels/Tires - Vehicle Vibration/Shake At Highway Speed
08-003-09 FEB 09 Audio System - Radio Inop. After Battery Disconnect
18-041-08 DEC 08 Engine Controls - ECM Update For Spark Knock/Vibration
21-022-08 OCT 08 A/T - Converter Shudder On Vehicles With Less Than 4K Mi
21-021-08 SEP 08 A/T - Repair/Replacement Guidelines
These are from AllData.com
(I wasnt going to pay for a subscription, info only)
http://www.alldatadiy.com/TSB/17/0917a1fC.html
Old 11-15-2009, 09:09 PM
Rogue's Avatar
Rep:22
Default Some more to consider
Automotive Recall and Technical Service Bulletin Titles for 2009 Dodge Truck RAM 1500 Truck 4WD V8-5.7L.
J08 JUN 09 Recall - Potential Clutch Pedal Link Separation (Canada)
H46 JUN 09 Recall - Steering Linkage Defects
J08 MAY 09 Recall - Clutch Pedal Linkage Rod Defect
H36 MAY 09 Recall - Drag Link/Steering Damper Bracket Defects
18-019-09 JUL 09 Engine Controls - MIL ON/Multiple DTC's Set
08-10-09 JUN 09 Parking Assist System - False Objects Indicated
18-016-09 MAY 09 Engine Controls - MIL ON/DTC's P1004/P2016/P2017
23-015-09 MAY 09 Body - Door Rubs On Fender When Opening/Closing
